What are these dash wires? - Team Camaro Tech
post #1 of 9 (permalink) Old Feb 6th, 15, 06:45 PM Thread Starter
I have 2 wires left right behind the radio area. I'm guessing one of these is for an ash tray light? No clue what the other is. My car's harness was butchered when I got it. This is a brand new AAW factory fit harness. (68 with console gauges)
Thanks for any help with this.
68_RS is offline
post #2 of 9 (permalink) Old Feb 6th, 15, 08:34 PM
Kevin
KevinW's Avatar
Re: What are these dash wires?
The orange barrel connector is likely the lighter. A yellow wire is usually the IGN switched Radio power wire.
Kevin
KevinW is offline
post #3 of 9 (permalink) Old Feb 6th, 15, 08:52 PM
Vega$69's Avatar
The AAW instruction tell you exactly what the wires are.
Vega$69 is offline
post #4 of 9 (permalink) Old Feb 6th, 15, 11:32 PM
Tim
Think that's just for the AAW Classic Update harness, at least the complete Factory Fit set I bought to rewire my car didn't come with instructions anyway.
Have to get the factory wiring diagrams to be sure, but Kevin's reply sounds correct.
1969 04A Van Nuys-built Z/28. Cortez Silver with dark blue interior and VE3. Sold Clippinger Chevrolet. Raced at Lions in LA.
ZLP955 is offline
post #5 of 9 (permalink) Old Feb 7th, 15, 05:52 AM
Orange is definitely the lighter - distinctive plug and the right color. Unfortunately I have a '67 so can't swear it's identical but the original harness had a yellow wire with that connector for the accessory switched power lead to the radio and I believe AAW tries to keep colors identical to original on the Factory Fit harness (not so much on the Classic Update).
1967 RS driver with a 327/210... but now with an M20, HEI, AAW harness w/ halogens and relays, Dakota Digital, Moto-Lita, TMI interior, and a few other toys
Brian_P is offline
post #6 of 9 (permalink) Old Feb 7th, 15, 06:56 AM
mike
go to American autowire and print out the instructions
mike
mikeyparts is offline
post #7 of 9 (permalink) Old Feb 7th, 15, 01:16 PM
According to my AAW schematics, orange is the cigarette lighter and the yellow is for the clock (optional)
69 Camaro X44
408ci
Terminator EFI
AFR 195's
XE274H
T56 Magnum
4:10 posi
12 Bolt
bkerns925 is offline
post #8 of 9 (permalink) Old Feb 7th, 15, 03:47 PM
ds1
Dan
Then if that is the case AAW is not accurate. The yellow is for the radio. That orange is for the lighter and the clock would be an orange wire coming from the fuse box on an accessory wire plugged into it
ds1 is offline
post #9 of 9 (permalink) Old Feb 7th, 15, 05:26 PM
Chris
130fe's Avatar
Look here on sheet 3, number 9 and 10.
http://www.americanautowire.com/PDFL...20IN%206.0.pdf
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
