1969 RS fuel gauge - Team Camaro Tech
post #1 of 21 (permalink) Old Feb 11th, 15, 07:03 PM Thread Starter
Alex
1969 RS fuel gauge
My fuel gauge is located is located in my instrument cluster. What's the best to get to the back side of it for trouble shooting and replacing it?
1969 RS Camaro
1972 K5 Blazer
2010 Dodge Ram 2500 4X4
1969RSCAMARO is offline
post #2 of 21 (permalink) Old Feb 11th, 15, 07:11 PM
Rich
Re: 1969 RS fuel gauge
Remove lower cover for the steering column and loosen the 2 nuts that support the steering column so that it will drop down a bit. You can then remove the screws at the top, bottom and left side of the dash bezel. You will also have to remove a couple of small nuts on the right side that are above the radio/ash tray area. The bezel will then slide forward and you should be able to get to the back of the gauge. It is not too difficult. If you have an assembly manual you can find all of the fastener locations easily
69 Z/28 RS clone. Azure Turquoise. First car--owned for 32 years and counting.
Rich Lordo is offline
post #3 of 21 (permalink) Old Feb 11th, 15, 07:38 PM
Karl
VetteFreak's Avatar
Alex...I removed the radio rather than dropping the steering column. With that out of the way, there was plenty of room to work on the rear for removal. By the way, if you need a replacement, I have a good clean one that works. Let me know if you're interested. I added the console gauges to my RS and installed the 350 tach in its place. Good luck
Karl / VetteFreak
69 Camaro RS 350/350TH...Burgundy...711-Black Int/Houndstooth Seats
2007 Corvette Conv. LS-2/A6...Monterey Red/Black Top & Int
VetteFreak is offline
post #4 of 21 (permalink) Old Feb 12th, 15, 02:35 AM Thread Starter
Alex
How much would you want for it?
1969 RS Camaro
1972 K5 Blazer
post #5 of 21 (permalink) Old Feb 12th, 15, 05:49 AM
Kevin
KevinW's Avatar
Alex/Karl, please take the negotiations offline, we try to keep the regular forums clear of the buying and selling thanks!
Replacing a gas gauge while lying on your back will be challenging. The electrical connectors are in about 6 pieces plus washers. Trying to juggle those up in that tight space, ouch!
What is the current issue? Most 69 gas gauge issues are related to grounding issues at the tank or the tank sending unit. I have rarely seen a gas gauge not work if the tank side is working.
So give us more info please!
Kevin
KevinW is offline
post #6 of 21 (permalink) Old Feb 12th, 15, 06:48 AM
Karl
VetteFreak's Avatar
Sorry Kevin...got caught up in the moment
Karl / VetteFreak
post #7 of 21 (permalink) Old Feb 12th, 15, 06:55 AM
Karl
VetteFreak's Avatar
Alex...you have a PM!
Karl / VetteFreak
post #8 of 21 (permalink) Old Feb 12th, 15, 11:19 AM Thread Starter
Alex
My fuel gauge is peg above full.Well I have been trouble shooting this for a couple of days and I feel like I have two problems with my fuel gauge.
1) I disconnect the plug in the trunk, grounded the wire on the car side going to gauge,turned key on and it did not move the needle. Then I went to the front of the car disconnected the plug just above the emergency brake and did the same and it did not move the needle. I also checked continuity on the wire going back to the trunk and it was good.
2) I checked for a good ground at the fuel sending unit. I also disconnected the sending unit ground and the gauge wire of the sending unit and check ohm resistence between them and did not read anything?
I have done alot of searching on this subject and the only thing I know for sure is I have continuity from the front connector to the back connector is good. Everything else is what I have read. Any suggestions would be great.
Thanks Alex
1969 RS Camaro
1972 K5 Blazer
post #9 of 21 (permalink) Old Feb 12th, 15, 11:36 AM
69-Pace's Avatar
Did you run the full trouble shooter? https://www.camaros.net/forums/showthread.php?t=195833
Just unplugging the sender lead in the trunk should have moved the needle way past full. But if it was there already you wouldn't see any activity. Grounding the harness lead to the body in the trunk should have pushed the needle past empty. Make sure you have a good ground to bare metal. Also check your fuse.
There should be resistance on the harness lead and on the sender lead. Since it is a 69 you can manipulate the sender with a wooden dowel through the filler neck lifting up will increase Ohm's. The sending unit needs the ground connected for that to work so that sounds like your issue in that test as you say you disconnected the ground.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #10 of 21 (permalink) Old Feb 12th, 15, 11:49 AM
FYI - Any time I'm working on something behind the dash, the first think I do is take the driver's side seat out. After that, you can put something soft on the floor and lay on your back while working behind the dash. Sure makes it a lot more comfortable.
69 RS, Hugger orange/black, Deluxe interior, Sony AM/FM/XM/CD, PS & PB. 355, forged pistons, Eagle rods, balanced, Iron Eagles, 9.4:1 CR, .038 quench, XR270HR Cam, Z28 intake, FAST-EZ EFI 2.0, Thorley Tri-Ys, TCI 700R4, 2400 stall, 3.42 posi
LukeWarm is offline
post #11 of 21 (permalink) Old Feb 12th, 15, 02:48 PM Thread Starter
Alex
Which fuse? I assume that there is power there because everything else is working. But I sure would like to get a look of the back side of the gauge.
post #12 of 21 (permalink) Old Feb 12th, 15, 06:25 PM
69-Pace's Avatar
Test the Pink lead for power. It should be the lower right of the fuse panel marked GAUGES. I assume you are speaking of the standard large right side instrument pod gauge and not the small center pod. The plug can be removed from the rear without removing anything if you can get under the dash on your back. Larger folks have to remove the drivers seat to get enough room to get under and be able to look up.
69-Pace is offline
post #13 of 21 (permalink) Old Feb 13th, 15, 06:26 PM
Jeff
yellow69RS's Avatar
As stated early a gauge past full indicates an open circuit from the sender. If you ground the wire at the rear and it doesn't go below empty the circuit is still open. If you ground the wire under the kick panel and it still isn't below full I would suspect the gauge is bad or something on the back of the dash.
Jeff
yellow69RS is offline
post #14 of 21 (permalink) Old Feb 13th, 15, 07:18 PM Thread Starter
Alex
I picked up a sending unit today and got a gauge on the way. But I still want to get a look behind that dash to check power, ground and the gauge wire.
1969 RS Camaro
1972 K5 Blazer
post #15 of 21 (permalink) Old Feb 14th, 15, 12:01 PM
Jeff
yellow69RS's Avatar
When you disconnect the wire in the trunk and nothing changes it tells you the present problem is not in the tank. After you get everything in front of there working as it should you may find the sender not reading correctly but it presently is NOT causing the gauge to read past full.
Jeff
