69 Camaro headlight switch install - Team Camaro Tech
post #1 of 14 (permalink) Old Feb 21st, 15, 05:37 PM Thread Starter
Timmy
Hi All
Just finished installing my Old Headlamp and Wiper Switch in my new Instrument Cluster/ Dash Carrier for my 69 SS/RS.
Went looking for a good Picture on the “Net”, got a Picture last year from another Team Camaro member of his but did not really show what I needed as my Switch was out of the Car in a box of Parts and the AIM is still a Cartoon.
The 3 Tabs for mounting my Wiper Switch were also cut a little short so I added some washers for a spacer.
Timmy
Name:	69 Camaro Headlight Wioer Switch install 003.jpg
ID:	101482   Click image for larger version
Name:	69 Camaro Headlight Wioer Switch install 004.jpg
ID:	101490   Click image for larger version
Name:	69 Camaro Headlight Wioer Switch install 005.jpg
Name:	69 Camaro Headlight Wioer Switch install 006.jpg
1969 SS/RS Coupe 427BB 700R4 12 Bolt 4:11 A/C, High School Resto Mod
November 1968 Build Date
french69ssrs is offline
post #2 of 14 (permalink) Old Feb 21st, 15, 06:23 PM
Tim
Re: 69 Camaro headlight switch install
Turned out nice, and the 200kph speedo looks great - I need to get mine over to Instrument Specialties for restoration in the next few months.
1969 04A Van Nuys-built Z/28. Cortez Silver with dark blue interior and VE3. Sold Clippinger Chevrolet. Raced at Lions in LA.
ZLP955 is offline
post #3 of 14 (permalink) Old Feb 21st, 15, 06:53 PM
69-Pace's Avatar
Looks great. Strange two extra holes on the face of your wiper switch. I take it its the one your car came with to you originally?
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #4 of 14 (permalink) Old Feb 21st, 15, 07:04 PM Thread Starter
Timmy
Hi Tim
OK, one more Picture to get you going
I installed my Retrosound 2 Radio for this Pic.
Will have it lying behind the Instrument cluster before Installation and bring it into the Housing after that is installed.
Timmy
Name:	69 Camaro Instrument Cluster 002.jpg
ID:	101514   Click image for larger version
Name:	69 Camaro Headlight Wioer Switch install 002.jpg
post #5 of 14 (permalink) Old Feb 21st, 15, 07:28 PM Thread Starter
Timmy
Hi Brian
Yes, I did notice the 2 holes and also looked at other pic's of Switches and did not see them there. I guess I'll call it adding "Character" to my car.
when I took it off the Old Instrument Housing, 2 of the 3 tabs were broke and it was Glued in and the Bottom areas were cut out for Switch panels I guess.
Here is before and after Pic's
Timmy
ID:	101530   Click image for larger version
ID:	101538   Click image for larger version
post #6 of 14 (permalink) Old Feb 21st, 15, 07:32 PM
69-Pace's Avatar
Yeah battle scars and maybe they were from a previous attempt to attach to the nibbled out dash carrier.
Sent from my iPhone using Autoguide
69-Pace is offline
post #7 of 14 (permalink) Old Feb 21st, 15, 07:46 PM
Vega$69's Avatar
Originally Posted by french69ssrs View Post
Hi Brian
Timmy
You can easily fill the holes with a plastic epoxy or something and paint the area black again.
Funny how chairs are perfect for staging dash clusters for pictures
Vega$69 is offline
post #8 of 14 (permalink) Old Feb 21st, 15, 08:23 PM
Apprentice
Jordan
Just noticed this forum. I am also installing my headlight switch. My question is, how does the strap fasten to the dash? Is it sandwiched under the dash carrier and lower dash brace with a screw? I have an assembly manual but can't figure that part out.
Thanks in advance.
jrdnduvall is offline
post #9 of 14 (permalink) Old Feb 21st, 15, 08:51 PM
69-Pace's Avatar
Hi Tim
Timmy
LOL I have pictures someplace of my new carrier set up in the living room. I even powered up the replacement blue light radio and tested it, Must be a strange Connecticut thing.
69-Pace is offline
post #10 of 14 (permalink) Old Feb 21st, 15, 08:55 PM
69-Pace's Avatar
Thanks in advance.
Jordan - The strap is held by the headlight switch, the lower wiper switch screw, and the lower carrier mounting bolt. Then the lead is connected to the frame to ground. Take a good look at Tim's photos in his first post in this tread.
69-Pace is offline
post #11 of 14 (permalink) Old Feb 22nd, 15, 08:13 AM
Everything looks real nice.
What brand dash carrier? I installed an OER a couple months ago - that sucker fought me every step of the way. The finished product looks excellent, though.
BPOS is offline
post #12 of 14 (permalink) Old Feb 22nd, 15, 02:17 PM
69-Pace's Avatar
OER is the only one that i know of currently on the market. HBC qualifies as a Value Added Reseller as they offer the OER carrier modified for all the available gauge options except Power top, or defogger or power top & defogger combo switches. They sell them pre painted to the common interior colors and IMHO an investment well worth the time and hassle.
As to fitment well everybody's vehicle has some history and you might find installing it on a hot day using sunlight to give you a little more bend is a good trick.
69-Pace is offline
post #13 of 14 (permalink) Old Feb 22nd, 15, 04:07 PM Thread Starter
Timmy
Al, Jordan and Brian
I guess some Close ups of the Ground Plate Assy between the Headlight Switch and Dash Carrier/ Instrument panel would be Helpful ?
Al, I bought my Dash Carrier/ Instrument Panel from Ground-up, they are like 20 minutes from my home and Super to do Business with, and I want to say it was an OER unit.
I had Mike over at Instrument Specialties in North Kingston, RI do the Swap over, again, Super people giving us what we want, Excellent products and good prices.
Jordan,
The Headlight Switch is held in with an Open Center, Outside Threaded nut that goes thru the Instrument Panel (In my case with the Wood Grain Inserts, it goes thru that First - Then the Instrument Panel) On the back side, there is a Tab from the Ground Plate that picks up the Lower Left Hand Wind Shield Wiper Switch Screw.
The large Round hole with the Slot in the Ground Plate picks up the Tab in the Headlight Switch which orients the Headlight Switch towards the Steering Column and gets "pinched" between the Instrument Panel and Headlight Switch.
The Lower Tab again gets Pinched between the Lower Instrument Panel Mount Flange and the Steel Dash Support assy and like Brian said, the Black Wire Terminal goes to the Lower part of the Steel Dash Support.
Sorry if I'm "killing this" but I like to have Pictures and any info when I'm looking for something - Hope it helps.
Timmy
Name:	69 Headlight Switch Close ups 001.jpg
ID:	101690   Click image for larger version
Name:	69 Headlight Switch Close ups 002.jpg
post #14 of 14 (permalink) Old Feb 22nd, 15, 08:12 PM
69-Pace's Avatar
Nice work Tim.
69-Pace is offline
