69 Clock Bulb too long - Team Camaro Tech
post #1 of 10 (permalink) Old Mar 5th, 15, 11:08 AM Thread Starter
Timmy
Hi All, another dilemma !
Last night, I am installing my Instrument Panel/ Dash Cluster with my Son.
Things are going “Slower” than I thought – Right ?
Took ½ hour to take apart, 5 hours to try and get back together.
Last thing was to install the 194 Bulb in the Clock Bulb Socket and “twist” into the Top of my New Clock, would not fit. Took the Bulb out and it goes in and Locks, so my Son said “get the Old Clock and see if it fits in there”.
I did and same thing, the Bulb hits the Green Lens.
I saw another Bulb P/N of 168, looked that up on the Net and it said they are the Same dimensional size, Just Brighter.
Is there a “shorter” Bulb used for the Clock.
The Socket is a whiteish color and what came out of my car, not spliced in. Original Clock/ Tach and Console Guages.
Thanks for any help.
Timmy
1969 SS/RS Coupe 427BB 700R4 12 Bolt 4:11 A/C, High School Resto Mod
November 1968 Build Date
french69ssrs is offline
post #2 of 10 (permalink) Old Mar 5th, 15, 07:07 PM
69-Pace's Avatar
Re: 69 Clock Bulb too long
194's are bayonet base. they do not twist.
The idiot lights and turn signals use 194.
The bulb you want is 168 for the clock and instrument illumination.
Consoles use 1445's for the automatic selectors.
Console Gauges use 1816
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 10 (permalink) Old Mar 6th, 15, 05:08 AM
Matt
That is too funny Timmy, I thought that I was the only one that encountered that problem. I have never heard of anyone else having that problem besides me. I too looked at the 168 bulb and it was the same size. Is there a "specific" 168 bulb that needs to be used? I could not get the socket to fully engage when I replaced the bulb years ago, and I thought it was just me. Let me know if you have any luck finding the correct bulb and where you got it from so that I can fix mine as well.
12 Bolt 3.55 Posi
461 BBC TKO600
Matt 69 is offline
post #4 of 10 (permalink) Old Mar 6th, 15, 05:34 AM
69-Pace's Avatar
Shoot a picture of the bulb housing and socket so we can actually see what you have.
69-Pace is offline
post #5 of 10 (permalink) Old Mar 6th, 15, 06:29 PM Thread Starter
Timmy
Hi Matt and Brian
Took a few Pics, went to Autozone, Advanced Auto yesterday, Radio Shack today and still looking thru the Net - Nothing.
Also contacted Sylvania Customer Service and spoke with a Girl there. She said she would get with some of the Senior (Older) guys and see if they had any answers.
The 194 Bulb in the Socket measures about 13/16 .810" long.
The Depth of both my New and Old Clock is about .705" so I am like .100" too long which is seen in Both Pictures where I have the Bulb/ Socket into the New Clock and Old Clock.
I did find on eBay an LED 194 Bulb, For $6.00, I'll see if it is any shorter.
http://www.ebay.com/itm/170877302734...%3AMEBIDX%3AIT
Timmy
Name:	1969 Camaro Clock Light Issues 001.jpg
ID:	103433   Click image for larger version
Name:	1969 Camaro Clock Light Issues 003.jpg
ID:	103441   Click image for larger version
Name:	1969 Camaro Clock Light Issues 004.jpg
Name:	1969 Camaro Clock Light Issues 006.jpg
ID:	103457   Click image for larger version
post #6 of 10 (permalink) Old Mar 6th, 15, 08:07 PM
Are all three sockets the same? (speedo, clock, tach) I recently installed a center fuel gauge which I assume is the same and pirated a socket of an old dash harness and it's a black plastic job that looks nothing like the white one you are showing.
BPOS is offline
post #7 of 10 (permalink) Old Mar 6th, 15, 08:36 PM Thread Starter
Timmy
Hi Al
The 2 other Sockets are Black and have the harnesses have the Black Plastic Clips that go into the back of the Instrument Housing/ Carrier.
I can only say of the several variables, I have had this car for like 15 years, 13 of them under a Car Cover.
My Son also took the dash apart like 2 years ago, I did not take any Pictures and the 2 wires/ White Socket came out of my harness along with the 2 Clock wires where they would drop off for the Clock and the Harness was wrapped for the entire length - I would say I did not see anything that would point me to think this was not a Stock Setup.
Picture is of my Harness when I had it laying in, White Plug in Red Circle.
I will look at that - Swapping that Clock to the Speedo or Tach and seeing if I can get the Black one to the Clock Hole.
Great observation, not trying to rewrite the Book, just get this car done this Spring.
Timmy
Name:	Clock Plug Harness.jpg
post #8 of 10 (permalink) Old Mar 6th, 15, 08:44 PM
That's the same black socket I used for the center fuel. If the clock is the same setup as center fuel, it should work with either of the wedge bulbs you were talking about. The white socket will also work in the speedo or tach. The black is not a 1/4 turn BTW. My harness has been spliced into many times - I have no idea what it's supposed to look like!
BPOS is offline
post #9 of 10 (permalink) Old Mar 7th, 15, 08:35 AM Thread Starter
Timmy
OK Al,
Good thinking “outside the box”
Sometimes I get too Tunnel Vision with how I want to do things, I don’t see the obvious
And for me, it’s not like anyone will be able to look in there and say, “that’s not correct”, I will just move that to the Speedo or Tach.
Again, I did not take that apart, my Son did.
And my car is all original SS/RS as far as the Clock/ Tach and Wire Harness (Not like this was added), could have been just something unique that happened at the Harness manufacturing shop.
Also, Matt from Florida, Post # 3 said he had the same problem with his Clock light.
Thanks for the Ideas.
Timmy
post #10 of 10 (permalink) Old Mar 7th, 15, 10:57 AM
69-Pace's Avatar
Been a long time but if I remember right the white socket should have the hole bored in it for fiber optic ashtray light. This should have been installed on the top of the right hand pod - fuel or tachometer. In any event there should be enough slack to reroute it.
In vehicles I have helped owners add center fuel or clock to that did not have either from the factory, the AAW clock harness comes with the instrument lamp circuit included so we never dug into the wrapping to find the unused socket. You plug it into the fused BAT option slot on the fuse panel for the clock and the second leg takes the dimmer feed LPS on the panel to power and dim the socket. The socket AAW supplies fits. You should also be able to remove the white and replace with generic one bought at the HELP section of the big box auto parts place in your neighborhood.
69-Pace is offline
