67 ignition voltage - Team Camaro Tech
post #1 of 16 (permalink) Old Mar 5th, 15, 04:15 PM Thread Starter
George
67 ignition voltage
Does the resistor wire that powers the coil in the run position have any voltage while cranking? I know the other wire from the starter supplies full battery voltage during cranking for quicker startups, but does the resistor wire cut out during crank or does it still have power?
carbuff67rs is offline
post #2 of 16 (permalink) Old Mar 5th, 15, 04:16 PM
George
Gbauer's Avatar
Re: 67 ignition voltage
I can't imagine why it wouldn't. In fact I'm almost 99.999999% sure it does. I don't think I had to run the wire from the starter to the coil when I went HEI. That tells me the red is hot during cranking.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #3 of 16 (permalink) Old Mar 5th, 15, 04:24 PM Thread Starter
George
Thats what i was thinking. My car is kinda "snowed in" right now so I cant check with a meter.
post #4 of 16 (permalink) Old Mar 5th, 15, 05:08 PM
George
Gbauer's Avatar
We got a foot today. I'm not trudging out to the garage to check mine right now either...
...but if you can find an HEI wiring diagram that should clear it up and keep both our feet warm.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #5 of 16 (permalink) Old Mar 5th, 15, 05:10 PM
George
Gbauer's Avatar
Yep. I was right. Stay warm my friend.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #6 of 16 (permalink) Old Mar 5th, 15, 05:13 PM
I feel for you George, it went just south of us here in southern NH for a change, we had spring temps yesterday but today we were back in the cold. At least for once this winter the snow missed us so we have no snow to shovel...
NH69Z28RS is offline
post #7 of 16 (permalink) Old Mar 5th, 15, 05:36 PM
No voltage on that wire during cranking on a 67 from the factory. The yellow wire from the solenoid to coil+ supplies voltage to the coil while cranking. When you release the key to the run position then there is voltage. In 68 and 69 the resistor wire does have voltage while cranking.
BPOS is offline
post #8 of 16 (permalink) Old Mar 5th, 15, 05:56 PM Thread Starter
George
Thats what I was afraid of. That hei conversion chart shows otherwise but it might be for 68 and up. I thought the 69 with the column mounted key did and I also know that he 67 and 68 ignition switches look the same but have different pigtails, and are not interchangeable. I wonder if this is something that was changed for 68. Gbauer, what year is your car?
Edit, I just saw its a 68.
post #9 of 16 (permalink) Old Mar 5th, 15, 06:29 PM
Seems like a jumper wire with a diode between START and RUN on the back side of the IGN switch should solve your problem.
BPOS is offline
post #10 of 16 (permalink) Old Mar 5th, 15, 07:53 PM
Nick
your ignition has a cranking power wire! just take the power from there
67 rs/ss 350 original eng,700r4, a/c, tilt, deluxe int,strato bench,Ca.emission,front disk,am/fm,floor clock,17" W/V Ralleys,Toyo T1S 255/40/17, 245/40/17
MRCOOL_RSSS350 is offline
post #11 of 16 (permalink) Old Mar 5th, 15, 07:58 PM Thread Starter
George
And its entirely possible thats what they did for 68. Im trying not to overthink this or make it too complicated. Ive seen where people use the coil wires to trigger a relay that gives a full 12v from the horn relay. Seems a bit much. Ive also seen the wire from the fusebox ignition terminal which seems easy enough but now Im even wondering if that has power during cranking either. People have been dropping hei's in old cars for decades so I figure it cant be rocket science.
post #12 of 16 (permalink) Old Mar 5th, 15, 08:05 PM Thread Starter
George
Yes, it does, then after cranking it goes dead and the resistor wire takes over that does not supply a full 12v which most performance ignition systems need to run properly. Id like to have just 1 wire to handle both situations like newer cars do. I dont want to have to combine a bunch of wires, trying to keep it simple.
post #13 of 16 (permalink) Old Mar 5th, 15, 08:33 PM
Doug
On my 67 Camaro I did away with the resistor wire at the bulkhead connector. Using the old terminal I ran a 14 gauge red wire to the MSD box. You could use this red wire for your HEI distributor.
Cdminter55 is offline
post #14 of 16 (permalink) Old Mar 5th, 15, 11:51 PM Thread Starter
George
Something like that was my plan. But if that terminal has no power when cranking. then I would still need to combine it with the other wire from the starter. Id like to have a 1 wire solution. Ideally, Id like to have 1 wire feeding the hei 12v in both cranking and run mode and just tape off and tuck away the original wires for use just in case. Im gonna have to check that ign terminal on the fusebox for voltage while cranking.
post #15 of 16 (permalink) Old Mar 6th, 15, 01:49 PM
I could be wrong, but I think the IGN wire will state hot during crank on a 68 ignition switch. Also seems like aftermarket ignition switches work like the 68 did. 67 for sure was an odd duck in that regard
dnult is offline
