Hacked Dash Wiring - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 14th, 15, 12:23 PM Thread Starter
kev
Hacked Dash Wiring
Previous owner did a number on some of the under dash harness. Found where most went but still have 4 problem areas. need help so I can get the interior buttoned up.
1) Black 14 ga.
2) black with white stripe 14 ga
Both of these are coming out of the harness together and I cannot find where they come from and finish.
3)Black 18 ga it appears to be that was cut off on the left side of the steering column. (Assume ground but do not know to what ).
4) Finally a 2-plug connector on the right of the steering column that has 2 pink on one terminal and a single green on the other. Cannot see where this goes to.
All help will be greatly accepted. My manual is very fuzzy and so are my electrical skills.
1969396 is offline
post #2 of 5 (permalink) Old Mar 14th, 15, 12:49 PM
69-Pace's Avatar
Re: Hacked Dash Wiring
Well Kev location in the harness, coupe or vert, gauges or warning lights might help more but here is the wiring diagram in color see if that helps you.
Name:	power distribution.jpg
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 5 (permalink) Old Mar 14th, 15, 03:24 PM Thread Starter
kev
This is for a '68 Z28 coupe with console gauges. Still need more detail instructions if at all possible. Not sure where everything goes.
1969396 is offline
post #4 of 5 (permalink) Old Mar 14th, 15, 06:24 PM
69-Pace's Avatar
Kev - Shoot us a few photos of what Dr. Frankenstein did to your harness and maybe we can help you restore it.
69-Pace is offline
post #5 of 5 (permalink) Old Mar 14th, 15, 08:42 PM Thread Starter
kev
Will try to get that done tomorrow
1969396 is offline
