67 Console Guages Wiring Ground Strap - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 17th, 15, 10:24 AM Thread Starter
Dale
Hi, I'm installing a new harness on my console guages. Where does the ground strap attach? My book says on the tunnel drivers side. I do not see a hole to attach it. My car has its original tunnel and was equipped with console guages. Could the ground strap have been connected somewhere else.
440six is offline
post #2 of 7 (permalink) Old Mar 17th, 15, 12:47 PM
Re: 67 Console Guages Wiring Ground Strap
I am not near my car at the moment but think I remember a black wire from the harness with a star ring crimped on it and that is secured either to the front console mount or tunnel with a screw. If you don't get a better reply by this evening, I'll be happy to check my car when I get home from work.
Melrose RS is offline
post #3 of 7 (permalink) Old Mar 17th, 15, 12:57 PM Thread Starter
Dale
Thanks appreciate it. If possible a picture would be nice.
440six is offline
post #4 of 7 (permalink) Old Mar 17th, 15, 01:38 PM
Bob
camarocards's Avatar
Dale,
If you're referring to the ground wire that is part of the console harness, see picture below. The ground screw is attached just to the right of the shifter (red arrow).
This picture is from a '68 but I would suspect it is the same on a '67.
Bob
Name:	Ground Screw_S.jpg
camarocards is offline
post #5 of 7 (permalink) Old Mar 17th, 15, 03:06 PM Thread Starter
Dale
Thanks, mine a 4 speed, I only have the 4 holes for the boot on top of the hump. I probably can secure it anywhere, just figured I may as well put it where it belongs.
440six is offline
post #6 of 7 (permalink) Old Mar 17th, 15, 05:54 PM
I checked my car and it is not how I described it above. My car was originally an automatic with console and gauges and is a first week of Jan 67 build. The grounding wire from the harness is attached to the underdash support on the right side of the radio.
post #7 of 7 (permalink) Old Mar 18th, 15, 08:15 AM Thread Starter
Dale
Thanks, I just checked my car and the bolt with a broken wire is still there. Appreciate all the help.
440six is offline
