Blown fuse - Team Camaro Tech
post #1 of 16 (permalink) Old Mar 26th, 15, 10:11 AM Thread Starter
Jeff
Blown fuse
Every time I go to start my 68 Camaro it blows the main 40 fuse. I've replaced it 4 times now and cannot figure it out. Help?
fordpowerjoke is offline
post #2 of 16 (permalink) Old Mar 26th, 15, 10:32 AM
Jess
Re: Blown fuse
Had a starter do that once. Changed it and fixed the problem. Not sure if thats your problem though. Good luck.
Jess67
67 Camaro Blue 427, 4-speed, 12 bolt
67 Camaro 350, 200-4R, PS, AC, PB, IN PARTS
Jess67 is offline
post #3 of 16 (permalink) Old Mar 26th, 15, 11:11 AM
Re: Blown fuse
Which fuse? Main 40A? Never heard of such a beast on a gen 1 Camaro. The starter motor circuit is not fused.
BPOS is offline
post #4 of 16 (permalink) Old Mar 26th, 15, 12:01 PM Thread Starter
Jeff
Yeah it's blowing the main 40A. As soon as the dash lights come on, they go back out and its blown.
post #5 of 16 (permalink) Old Mar 26th, 15, 12:13 PM
69-Pace's Avatar
Re: Blown fuse
Any recent electrical or electromechanical changes made to the vehicle?
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #6 of 16 (permalink) Old Mar 26th, 15, 12:50 PM
Timmy
Re: Blown fuse
Hi Jeff
Like Al wrote, I thought the largest fuse is a 25 Amp.
You need to Isolate your circuits, Sounds like one has gone to ground.
1 - Does the Fuse Blow when you turn your Ignition Key to the Run Position ?
Then it Blows when you rotate it to the "Start" Position ?
and do you hear the Starter make any noise ?
2 - I would Remove the Purple Wire to the Starter, with a new Fuse or Short Circuit Tester in place of the Fuse, Turn the key to where it was blowing the Fuse. If that is OK, I would Change the Starter Solenoid/ Starter assy.
3 - If your problem continues, then you should remove the Wire Harness Ignition Switch Plugs and ring out each Circuit to see which one is Grounded.
4 - I would say the Ignition Switch is the Cause. If you can get one from somebody and try it.
What is happening is when you install a new Fuse and Turn your Key, it is taking that Voltage and running it into a Wire (Purple) past the Neutral safety switch to "pull" the Starter Solenoid into Contact to turn the Starter.
Timmy
Name:	1969  Camaro wiring diagram.jpg
ID:	105585   Click image for larger version
Name:	1969 Camaro Fuse Panel.jpg
1969 SS/RS Coupe 427BB 700R4 12 Bolt 4:11 A/C, High School Resto Mod
November 1968 Build Date
french69ssrs is offline
post #7 of 16 (permalink) Old Mar 26th, 15, 01:20 PM Thread Starter
Jeff
It blows as soon as the key goes to the run position, there is not enough time to get it to crank before it blows
post #8 of 16 (permalink) Old Mar 26th, 15, 01:23 PM
Re: Blown fuse
There is no "40 main fuse". Which fuse is blowing - as in what position on the fuse block.
BPOS is offline
post #9 of 16 (permalink) Old Mar 26th, 15, 01:25 PM Thread Starter
Jeff
It's hard to tell if it's the starter because the fuse blows before I can turn the key past run.
post #10 of 16 (permalink) Old Mar 26th, 15, 01:27 PM Thread Starter
Jeff
It's not one of the fuses on the fuse block. Look by the driver head light and there is a little black capsule with an orange fuse. That one is blowing each time.
post #11 of 16 (permalink) Old Mar 26th, 15, 01:33 PM Thread Starter
Jeff
This is the fuse
post #12 of 16 (permalink) Old Mar 26th, 15, 01:36 PM
Re: Blown fuse
Is that part of the factory harness? I'm not aware of a replaceable fuse there. There are fusible links in that area near the horn relay, maybe a P/O blew a fusible link and installed a fuse there - who knows. Can you post a picture? Trace the wire and see where it connects?
Edit - yeah - that's not factory - someone added that. Would be easier to help if we knew what it was for.
BPOS is offline
post #13 of 16 (permalink) Old Mar 26th, 15, 01:59 PM
Jason
blue89bird's Avatar
Re: Blown fuse
Thats not factory at all. Where does it come from and where does it go?
Jason
2009 CTS-V - 1968 Camaro 327/M20 Sequoia Green
blue89bird is offline
post #14 of 16 (permalink) Old Mar 26th, 15, 02:46 PM
Timmy
Re: Blown fuse
Hi Jeff
As Al and Jason have asked, Where did this Modification come from ?
Your Car is a 1968 ?
Original Wire Harness - Patched into - Something Added or an Aftermarket Harness ?
When was the Last time your Car was OK,
as in What was done that changed the Configuration of your Electrical System or a Component replaced. Did you drive it to where it is and Now you have a Problem without having Done Anything ?
That Fuse and Location are not Stock.
I added a Picture of the 69 Wiring Diagram and Highlighted a few areas -
The Large Red Circle is where your Power distribution comes from, the Smaller Red Circle is Where that Power goes and the Yellow is how it gets from the Battery to the Voltage Regulator across the Radiator Support in the Stock application.
We need more Info and Pictures to help without totally guessing.
Timmy
Name:	1969 Camaro Wiring Diagram Help.jpg
post #15 of 16 (permalink) Old Mar 26th, 15, 03:41 PM Thread Starter
Jeff
Alright, I got it figured out, thank you.
