1968 camaro no blinkers now. - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 26th, 15, 10:03 PM Thread Starter
Chuck
I had blinkers when working on wiring. had to pull steering column down to remove gauge cluster. So I could install new dash pad installed everything. Now no blinkers But when I put a test light into the wire either the blue right front or the yellow right rear the blinker works. But when I remove the tester the light on dash stays on and nothing outside works.
Anybody know??????
gunsm is offline
post #2 of 6 (permalink) Old Mar 27th, 15, 04:27 AM
Karl
VetteFreak's Avatar
Re: 1968 camaro no blinkers now.
Anybody know??????
Check to make sure all dash panel grounds were restored...or, possibility when you disturbed the connections in the large quick disconnect above the steering column, dirt may have contaminated the source. If grounds are fine, clean connector with contact cleaner and try again.
Karl / VetteFreak
69 Camaro RS 350/350TH...Burgundy...711-Black Int/Houndstooth Seats
2007 Corvette Conv. LS-2/A6...Monterey Red/Black Top & Int
VetteFreak is offline
post #3 of 6 (permalink) Old Mar 27th, 15, 04:33 AM
Dan
your top center mounting screw on your guage cluster makes the ground connection to your main dash structure. this ground point is a common problem for guage/lighting issues it gets rusty/corroded. it is also a good idea to run a seperate ground wire from your guage cluster to a ground point under dash for better connection
68 camaro RS 327/275 THM350 4 wheel disc brake 8.5 10 bolt 3.42 daily driver
icpop is offline
post #4 of 6 (permalink) Old Mar 27th, 15, 04:42 PM
Sounds to me like a blown bulb(s).
my 67' build thread:
allanjs is offline
post #5 of 6 (permalink) Old Mar 27th, 15, 05:40 PM
69-Pace's Avatar
I think grounds followed by an inspection of the "harmonica" on the lower half of the steering column for broken or loose connections moved when the steering column was dropped. Also as noted your year has notorious issues with the grounds. Many add a real ground wire.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #6 of 6 (permalink) Old Mar 31st, 15, 07:46 PM Thread Starter
Chuck
Thanks for the help on the blinkers.
I did find the problem. I'm running all led bulbs and blinker wont work with out the flasher with the ground wire so I changed the front blinker /parking bulbs and everything works just fine now.
Again thanks for all the suggestions I did fix the bad looking grounds.
gunsm is offline
