Strange relay sound under hood. - Team Camaro Tech
post #1 of 22 (permalink) Old Mar 27th, 15, 01:37 PM Thread Starter
George
Ive got a 67 RS 327 with factory ac and working headlight motors. When I start my car after about 1 second I hear this "tink" sound which sounds just like the sound of my RS headlight relays when they open or close. If I have the door open with courtesy lights on I can see they are a bit dim until the tink sound then they are nice and bright and steady. Is this sound normal and what the horn relay is supposed to do? Aside from the RS relays, I have the big relay on the ac suitcase too. I have a 10si alternator and believe the external regulator is bypassed. I have not been able to narrow down which relay is making the sound. I dont have power windows and its not a convertible.
carbuff67rs is offline
post #2 of 22 (permalink) Old Mar 27th, 15, 03:42 PM
Karl
VetteFreak's Avatar
Re: Strange relay sound under hood.
The horn relay feeds the ignition and light switches (#12 red wire) from the key warning buzzer circuit. It could very well be your problem if it's sticking open. Can't imagine the A/C relay would affect it.
Karl / VetteFreak
69 Camaro RS 350/350TH...Burgundy...711-Black Int/Houndstooth Seats
2007 Corvette Conv. LS-2/A6...Monterey Red/Black Top & Int
VetteFreak is offline
post #3 of 22 (permalink) Old Mar 27th, 15, 04:38 PM
I don't think 67s had the key buzzer.
I was thinking it might be your AC clutch engaging
BPOS is offline
post #4 of 22 (permalink) Old Mar 27th, 15, 05:00 PM
Karl
VetteFreak's Avatar
The same horn relay was used for 67-71 and therefore contains the circuitry to the ignition and headlights as described in a previous post, regardless of the buzzer circuit.
Karl / VetteFreak
post #5 of 22 (permalink) Old Mar 27th, 15, 06:41 PM
As far as headlights, ignition etc. are concerned the horn relay is simply a connection point for the dash power-up wire via a busbar. The relay itself also gets 12v+ from that busbar. The relay is activated when the horn button completes the ground side of the circuit.
The 67 horn relay was different than 68-9. It had no provision for the key minder, and therefore only 2 male spades on the bottom - one for the wire from the horn button, and one to the horns. The 68-9 relay had a third male spade, that being for the key minder.
BPOS is offline
post #6 of 22 (permalink) Old Mar 27th, 15, 06:48 PM
Lars
Probably is the Charging Relay!
Black Box on Firewall beside the wipermotor.
You can get a new one that is Electronicaly controlled with Transistors, that will fix it.
LPS
LarsPerformance is offline
post #7 of 22 (permalink) Old Mar 27th, 15, 07:00 PM
LPS
Charging relay???
BPOS is offline
post #8 of 22 (permalink) Old Mar 27th, 15, 07:00 PM
jared
I had the same kinda sound. Unfortunately one of the headlight door limit switches had failed and the door kept trying to close which was poping the breaker or relay. Bad news was it fried the 100.00 motor before it caught it. So I've hooked up a toggle switch that powers the RS headlight doors. Flip it up to open then slip it down to kill power.
jcfcamaro is offline
post #9 of 22 (permalink) Old Mar 27th, 15, 08:29 PM
Nick
get some one to start the car for you and put your hand up where the relays are for your head lights, I bet you will feel the click on the circuit breaker
67 rs/ss 350 original eng,700r4, a/c, tilt, deluxe int,strato bench,Ca.emission,front disk,am/fm,floor clock,17" W/V Ralleys,Toyo T1S 255/40/17, 245/40/17
MRCOOL_RSSS350 is offline
post #10 of 22 (permalink) Old Mar 27th, 15, 09:48 PM Thread Starter
George
Just got home from work. This is what I was thinking, that a limit switch might be causing a relay to stick. Its the same sound as when I open or close the headlights. So it might be the 10 amp breaker for the headlight relays that is clicking like this? And the horn relay is only for the horn aside from being a bus location for 12v feed? As for the charging relay, which I am guessing is the regulator, as I said, its not in the system anymore as Ive got an internally regulated 10si alternator. I will have to disconnect the power to the rs relays to see if it fixes the issue. Maybe sunday.
post #11 of 22 (permalink) Old Mar 28th, 15, 02:25 AM
69-Pace's Avatar
The Horn Relay is an Swiss Army Knife tool of that GM era. It relays full power to the horns, and also acts as the main accessory power "Bus-bar" for the charging system, and feeds one side of the factory gauge equipped Ammeters and in later years it also acted as the "Key-minder" buzzer.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #12 of 22 (permalink) Old Mar 28th, 15, 08:13 AM Thread Starter
George
Just thought of something. This sound only occurs when I start the motor, after it is running, not when the key is just put in run. If it had to do with the headlights it would happen when the key was put in run also. It seems like it has to do with the altrnator starting to charge. The regulator is "bypassed" for the 10si alt but there are still 2 wires attached to it. Maybe those wires are still activating something inside of it. I will have to unplug it completely and see if it goes away.
post #13 of 22 (permalink) Old Mar 28th, 15, 11:14 AM
Karl
VetteFreak's Avatar
The horn relay receives power from the battery/charge circuit via the alternator. There should be a large "red" wire connected to the horn relay from the alternator regardless of internal/external voltage regulation. I still say, it could be the problem. Forget, for the sake of discussion, what I said earlier about the "key warning buzzer" circuit in a previous post, it still operates on the same principle as the 68-69 relay minus the buzzer. Remove that wire from the relay and see what happens...
Karl / VetteFreak
post #14 of 22 (permalink) Old Mar 28th, 15, 01:24 PM
Not to hi-jack this thread but Brian, your post triggered my memory that since I took possession of my current 69, it has not had a functional key minder-buzzer. While it's not something very high up on my list of priorities, it is something I planned on looking into at some point. I believe the horn relay was replaced just before I got the car and my original console ammeter works fine. Might it simply be the incorrect horn relay, or could it be the wiring was installed reversed?
NH69Z28RS is offline
post #15 of 22 (permalink) Old Mar 28th, 15, 01:29 PM
the day after I brought my 68 home from dealer I unplugged the buzzer. Was new.
john68 is offline
