1968 Camaro. Help Please. No Blinkers Now - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 27th, 15, 08:33 PM Thread Starter
Rob
Help. My blinkers have been working fine. I installed the backup light switch all of a sudden the backing switch doesn't work and now the blinkers do not work. I didn't do much with wiring, other than plug in the backup light harness. Any ideas? I checked and do not have power at the dash plug, I checked the fuse at the panel, and nothing. Is there a fuse somewhere else?
Rob
Griffir is offline
post #2 of 3 (permalink) Old Mar 28th, 15, 03:59 AM
Apprentice
Andrew
Re: 1968 Camaro. Help Please. No Blinkers Now
Hello Rob,
I would suggest undo the work that you did. Confirm blinkers work. Then check back up switch, power and the circuit to the back up lights. Then you could start the install again if everything checks out okay. It most case's it is normally the last person that touched it who caused the fault. Use a good quality Digital multi meter and test light.
Andrew
AndrewJ is offline
post #3 of 3 (permalink) Old Mar 28th, 15, 08:20 AM
69-Pace's Avatar
Check your fuse, the grounds, and for any loose or broken wires caused by the installation of the backup switch.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
