67 rs electrics faulty - Team Camaro Tech
post #1 of 18 (permalink) Old Mar 29th, 15, 05:57 PM Thread Starter
Question 67 rs electrics faulty
Connect battery cables and tail lights and parking lights come on. All new wiring. WHY
farrier is offline
post #2 of 18 (permalink) Old Mar 29th, 15, 06:29 PM
69-Pace's Avatar
Re: 67 rs electrics faulty
Double check all your grounds and the snug fit of both the headlight switch and the foot dinner. DO the RS electric doors open for parking lights?
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 18 (permalink) Old Mar 30th, 15, 04:15 AM
Headlamp switch has the button/knob in the wrong place internally.
Or, parking light power lead from switch is swapped with dome light power lead.
post #4 of 18 (permalink) Old Mar 30th, 15, 04:06 PM Thread Starter
Angry Re: 67 rs electrics faulty
Disconnected dimmer switch and headlight switch, no change
farrier is offline
post #5 of 18 (permalink) Old Mar 30th, 15, 04:20 PM
What changes have you made since the last time it was OK? If that's the entire harness, what brand/type of harness did you use?
1967 RS driver with a 327/210... but now with an M20, HEI, AAW harness w/ halogens and relays, Dakota Digital, Moto-Lita, TMI interior, and a few other toys
Brian_P is offline
post #6 of 18 (permalink) Old Mar 31st, 15, 05:04 AM
With headlamp sw unplugged, pull fuse.
If lights go out, fuse panel wired wrong, I suspect.
post #7 of 18 (permalink) Old Mar 31st, 15, 05:18 AM
First, welcome to the forum. I see this is your first topic you've posted about. We don't charge by the word so feel free to add more detail to your explanation and I'm sure we can help you get to the bottom of it.
Do you have the harness fully or just partially connected?
Sounds like you may have something connected to ground that should not be.
Melrose RS is offline
post #8 of 18 (permalink) Old Apr 1st, 15, 11:32 AM Thread Starter
All wiring harnesses are new,purchased at Classic Ind. Been going over all grounds again. Lights are STILL on.
farrier is offline
post #9 of 18 (permalink) Old Apr 1st, 15, 11:36 AM
69-Pace's Avatar
Have you followed Everett's suggestions yet?
69-Pace is offline
post #10 of 18 (permalink) Old Apr 3rd, 15, 07:43 AM Thread Starter
Pulled fuse, lights went out. Could it be possible it's the emergency flashers? I have no flasher plugged in yet, and just checked, the switch won't move in or out. Thanks.
farrier is offline
post #11 of 18 (permalink) Old Apr 4th, 15, 03:00 PM
No, because you said parking lights came on, not the turn signal filaments - two different circuits.
Emergency switch is hard to pull out for ON.
If pulled ON, lights won't light because light power goes through the flasher.
Fuse panel wired wrong.
post #12 of 18 (permalink) Old Apr 4th, 15, 07:08 PM Thread Starter
Update; just disconnected half moon shaped column connection and NO lights. But what does that tell me? Thanks guys
farrier is offline
post #13 of 18 (permalink) Old Apr 4th, 15, 10:03 PM
By unplugging the connector, the turn signal filaments have no power
Parking lights are brown wire to the sockets, comes from headlamp switch, or should.
These two diagrams should help.
post #14 of 18 (permalink) Old Apr 5th, 15, 08:19 AM Thread Starter
Thankyou Everett, it was the brake and turn signal filaments staying on. What do you suspect, steering column wiring or cam switch?
farrier is offline
post #15 of 18 (permalink) Old Apr 5th, 15, 07:12 PM
If turns are on, then I would suggest two problems:
1. With no emerg flasher fuse panel wired wrong
2. Emerg switch stuck on.
Only way for turns to get power if ign key is not on.
