Best way to run wire through firewall? - Team Camaro Tech
post #1 of 20 (permalink) Old Mar 30th, 15, 04:07 PM Thread Starter
George
Im going to be running a 12v wire from my fusebox to my coil soon. I dont want to cut off the original wire, I just want to run a new one. Where is the best place to run it? Ive considered the large rubber grommet for my ac harness as a possible place and also where the vacuum line runs for my ac controls but Im wondering If Im missing something obvious. I dont want to drill any holes either. What have you guys done?
carbuff67rs is offline
post #2 of 20 (permalink) Old Mar 30th, 15, 04:10 PM
Vega$69's Avatar
Re: Best way to run wire through firewall?
The best is to simply replace the existing wire from the firewall connector to the coil
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 20 (permalink) Old Mar 30th, 15, 04:28 PM Thread Starter
George
Maybe, but as stated I dont want to do that. I want to retain the stock wiring just in case I ever need or want to go back to points. Do all 67s have the backup light hole in the firewall? Or just factory 4 spd cars?
post #4 of 20 (permalink) Old Mar 30th, 15, 04:50 PM
George
Gbauer's Avatar
Just keep the wire then.
It's literally just a matter of pulling out the plug, replacing the connection and running wire.
It's the best way to do it.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #5 of 20 (permalink) Old Mar 30th, 15, 05:02 PM
Kevin
KevinW's Avatar
I ran a #4 amp wire through the lower firewall pad rubber plug hole. Running small wires through the pad plugs is an old school thing for the tach wire.
Kevin
KevinW is offline
post #6 of 20 (permalink) Old Mar 30th, 15, 05:42 PM
Alex
I ran my pertronixs 12 volt 14 gauge red wire from my fuse box ign terminal up and out through the speedometer cable hole and tie wrap to existing harness up to and next to the coil. I know it's there but a neat installation. I took my yellow wire and resistance wire and tape around the connector and tuck it up out of the way in the harness tray.
1969 RS Camaro
1972 K5 Blazer
2010 Dodge Ram 2500 4X4
1969RSCAMARO is offline
post #7 of 20 (permalink) Old Mar 30th, 15, 06:19 PM Thread Starter
George
I forgot about the rubber plugs. That sounds do-able. The speedometer hole sounds promising too. I currently have no speedo cable so I will have to plan for the future when I get one.
post #8 of 20 (permalink) Old Mar 30th, 15, 06:33 PM
Bobby
You can remove the resistor wire from the fuse box and coil connector and save it. Make a new 14g wire with factory connectors and replace it inside the harness, no one will tell the difference + you'll likely not go back to points but, if you do you'll have the wire still.
Where on LI are you?
67 Camaro 350
M20 4spd console,
8.5, 30 spline Eaton posi 373
Cowl Plenum
Custom 180 Headers
black/black
no radio
Luwi67 is offline
post #9 of 20 (permalink) Old Mar 30th, 15, 07:18 PM Thread Starter
George
Suffolk, North shore, around Port Jeff.
post #10 of 20 (permalink) Old Mar 30th, 15, 07:27 PM
Bobby
HaHa, that's where I am, I can help you with the factory crimps and Packard terminals if you end up doing what I suggested. That's the route I went.
67 Camaro 350
M20 4spd console,
Cowl Plenum
Custom 180 Headers
black/black
no radio
Luwi67 is offline
post #11 of 20 (permalink) Old Mar 30th, 15, 08:43 PM Thread Starter
George
Cool, small world, Ill keep it in mind. Still trying to figure out my best option.
post #12 of 20 (permalink) Old Mar 30th, 15, 09:06 PM
Bobby
Like John said in post#2 just replace it. You don't have to remove the wire from the car if you don't want to, just unplug it from the back of the fuse box and the coil and tie it off. Run a new 14g the same route as the original resistance wire plug it in the same location in the fuse box.
Do you still have the original wrap on the engine bay harness?
67 Camaro 350
M20 4spd console,
Cowl Plenum
Custom 180 Headers
black/black
no radio
Luwi67 is offline
post #13 of 20 (permalink) Old Mar 30th, 15, 10:49 PM Thread Starter
George
Yeah, still the original. I dont quite understand how to replace the wire. Dont I have to unplug the harness from the connector block in the engine compartment to do that? Its old and fragile and Im worried about breaking it. Ive seen posts where people broke the lock tabs off the connector and had to rig it to stay plugged. Im trying to avoid that type of thing.
post #14 of 20 (permalink) Old Mar 31st, 15, 08:30 AM
Bobby
OK, so you would just leave the wire in place after it's unplugged. I would run the new wire along the same path and secure it to the harness with tiny black zip ties. I got rid of all the factory harness wrap in the engine bay and used black loom (I hope I don't end up regretting that).
I did mine a while ago and I remember the firewall connector was not very difficult to deal with. If I remember correctly, I took the firewall connector off and stuck a tiny screwdriver in from the inside of the connector to bend down the retaining tab on the terminal. Remove the resistance wire and terminal from the connector (you would end up tying it back to the harness with black electrical tape, it's only 1-2") and plug in the new 14g wire with factory style terminal, snap the firewall connector back together and run your new wire along the backside of the engine harness and your done. If need be I have 3M strip calk to repack the back of the firewall connector if yours is deteriorated.
I think that is your best option, it's clean, durable, discreet and, reversable.
67 Camaro 350
M20 4spd console,
Cowl Plenum
Custom 180 Headers
black/black
no radio
Luwi67 is offline
post #15 of 20 (permalink) Old Mar 31st, 15, 09:35 AM
Vega$69's Avatar
The engine and light harness is bolted with one bolt in the middle. The are no clips to break. Just unscrew the bolt and pull it off.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
