69 AC Blower motor - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 17th, 15, 04:25 PM Thread Starter
Alex
69 AC Blower motor
My blower works on low and on high speeds but does not work on med speed? What and where should I look and test? Pictures always help. Thanks Alex
1969 RS Camaro
1972 K5 Blazer
2010 Dodge Ram 2500 4X4
1969RSCAMARO is offline
post #2 of 3 (permalink) Old Apr 17th, 15, 07:13 PM
Coppertop's Avatar
Re: 69 AC Blower motor
The first thing to check is the resistor assembly. This is mounted on the evaporator "suitcase" under the hood. You'll see a number of multi colored wires with a plug going into it. Unplug the connector and inspect for corrosion or damage. Then remove the 2 hex head screws and pull out the resistor assembly. They are wire wound resistors that resemble springs once pulled out of the case. Many times these corrode or go open from age. The resistors drop the voltage for the blower speeds--every speed but high.
Coppertop is offline
post #3 of 3 (permalink) Old Apr 19th, 15, 05:11 AM Thread Starter
Alex
I took the resistor out cleaned the terminals up reinstalled and got it working.
1969 RS Camaro
1972 K5 Blazer
