Fuse block / bulkhead to firewall foam seal ??? - Team Camaro Tech
post #1 of 12 (permalink) Old May 31st, 15, 05:53 PM Thread Starter
This question is about the foam seal on the fuse block / bulkhead that seals it the firewall and also seals it to the two wiring harnesses that connect to it on the engine side. My seal is still intact but it doesn't look like it has much compression left in it.
Can you buy a replacement seal anywhere? I looked in the usual catalogs but didn't see it. If a replacement seal is not available, I guessing you can just apply some sealant. I wondering what other people have done and used if their original seal was bad.
Thanks....Dave
daven1256 is offline
post #2 of 12 (permalink) Old May 31st, 15, 07:17 PM
Doug
Re: Fuse block / bulkhead to firewall foam seal ???
Just go to the auto parts store and get this. http://shop.advanceautoparts.com/p/p...058/12027861-P
Cdminter55 is offline
post #3 of 12 (permalink) Old Jun 2nd, 15, 03:15 PM
Larry
My first thought would be to get a computer mouse pad and make one.
Current Project:
69 Z/28 Resto-Mod
Next In Line:
83 Z28 Restoration
69-er is offline
post #4 of 12 (permalink) Old Jun 2nd, 15, 03:39 PM
Doug
How about these sheets of foam, are they too thick? http://www.summitracing.com/parts/fe...FUsXHwodo74AAw
post #5 of 12 (permalink) Old Jun 2nd, 15, 04:31 PM
Darin
ilikeike's Avatar
Maybe American Auto wire has them ? I know my new AAW harness had a nice thick pad.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is online now
post #6 of 12 (permalink) Old Jun 2nd, 15, 08:36 PM
69-Pace's Avatar
Lectric Limited used to have them. http://www.lectriclimited.com/mainpage.htm
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #7 of 12 (permalink) Old Jun 10th, 15, 02:29 PM Thread Starter
Thanks for all the suggestions.
I am sure the dielectric grease would have worked but just wasn't crazy about using grease there.
I looked at Fel-pro gasket material at the local auto parts store and what they had would not have worked.
I contacted American Auto Wire and they would not sell a gasket outright.
I did not see the gasket on Lectric Limited's website.
So what I did was go to a local electronics surplus house where that have all kinds of oddball stuff. I found some 3/16 inch thick foam sheets there for $1.50 for a 12 inch by 12 inch sheet. The first thing I did was to make sure that it would not let water penetrate it. It passed that test. I made a template and used it to cut a new seal from the foam sheet. It fit really well and I think it is going to work fine.
The old gasket was held on by some sort of reddish brown rubber glue. Getting that off was no picnic!
I have a couple more questions about the fuse block but I am going to start a new thread instead of burying them at the end of this one.
post #8 of 12 (permalink) Old Jun 10th, 15, 02:34 PM
George
Gbauer's Avatar
I just used dielectric grease. Same as I use for bulbs and just about any other electrical connection.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #9 of 12 (permalink) Old Jun 10th, 15, 04:37 PM
Larry
Dielectric grease would be fine to seal the cavities but I don't think for use as a weather seal over a large area. Dave's foam looks like it's the ticket!
Current Project:
69 Z/28 Resto-Mod
Next In Line:
83 Z28 Restoration
69-er is offline
post #10 of 12 (permalink) Old Jun 10th, 15, 10:43 PM
Darin
ilikeike's Avatar
That looks great
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
post #11 of 12 (permalink) Old Jun 11th, 15, 10:53 PM
Wayne
Nice job it looks great!
Wayne
69 Camaro SS/RS. Fab 9. GM LSA/485 crate drive train. . C6 Z51 brakes. AirRide G bar Rushforths 18x8 19x12
Motown 454 is offline
post #12 of 12 (permalink) Old Jun 11th, 15, 10:55 PM
Tim
Yes, good job Dave
1969 04A Van Nuys-built Z/28. Cortez Silver with dark blue interior and VE3. Sold Clippinger Chevrolet. Raced at Lions in LA.
ZLP955 is offline
