Hey fellas, getting to the end of my build and working on finishing up Classic Auto Air and installing modern stereo.
Come to an issue on wiring harnesses, since I never removed the stock components, I'm trying to figure out which harness went to what on passanger side of vehicle.
I assume the harness with glove box bulb attached, went to heater box??
And shorter loom went to radio?
I ask because instructions for Classic Auto wants you to tap into brown wire (for most GM vehicles), however I do not see a brown wire on the heater harness? Would it be a differant color on a 68?
Also, does the orange wire that goes to fan in engine block get used in Classic Auto/Vintage Air setup?
Also on modern radio, not sure what on old harness is always hot versus hot with key on?
I have searched and also looked up harnesses, but can't seem to find what I am needing.
