69 Camaro Wiring Harness - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 17th, 15, 06:18 AM Thread Starter
So after reading several posts on this subject, I purchased The AAW Classic Update series wiring harness kit (complete wiring kit - 1969 Camaro). I was only looking at AWW and M&H.
http://www.americanautowire.com/shop...it-1969-camaro
Started to install - had dash harness, taillight harness, installed and started working on engine harness. This is where I ran into some issues.
Apparently you cannot use this kit if going with factory alternator and ammeter (gauge in console). I have been informed if I want to continue to use this harness, I must replace the alternator (to internal regulated) and the ammeter gauge in the console will not be able to be used.
AWW informed me, I must now purchase their OE style harness kits if I want to use original style components. M&H sells similar, but has the upgraded fuses. For safety reasons - thinking about going with M&H. Has anyone used their harness kits or should I stay with AWW?
Also - I will be selling the AWW complete kit (did not split any wires, so like new). Paid $625, but will let go for $500 (free shipping). PM me if interested.
mnawalters is offline
post #2 of 5 (permalink) Old Jul 17th, 15, 06:35 AM
Vega$69's Avatar
Re: 69 Camaro Wiring Harness
I don't understand your safety concerns.
The ammeter in the console has full battery power through and a volt meter is better and safer.
Changing out the alt is not expensive and you will probably end up with a higher amperage.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 5 (permalink) Old Jul 17th, 15, 07:47 AM
X2 what John said, I wish I went that route at the beginning of my build. By the time I went through my car, I basically ended up changing all the wiring (except under the dash) using OEM harnesses, time I got done I spent more than going your route. And now I wish I had upgraded to modern fuse box and altenator. Makes adding modern addtions much easier that trying to find comparable connections on the OEM system.
1968 Camaro SS 396 M20 Posi
PhantomRider is offline
post #4 of 5 (permalink) Old Jul 17th, 15, 04:15 PM Thread Starter
John,
Thanks. I guess I should have clarified on the safety front - with M&H I was thinking of going with new fuse box (ATC) blade type fuses as opposed to older style glass body type. I plan to keep the original gauges in the console (not change from ammeter to volt meter). I don't think there is a way to use the AW harness, but keep the ammeter functional.
I can see why the issue with ammeter though - having full battery power passing through - sure hope everything is grounded properly.
post #5 of 5 (permalink) Old Jul 17th, 15, 04:29 PM
Vega$69's Avatar
Originally Posted by mnawalters View Post
John,
Classic Update does have the new ATC Bladed Type fuses.
And it's relatively easy run a wire to use the existing ammeter.
Vega$69 is offline
