69 Factory tach with HEI ignition - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 6th, 15, 08:44 PM Thread Starter
Craig
Craig1969's Avatar
Send a message via AIM to Craig1969 Send a message via MSN to Craig1969 Send a message via Yahoo to Craig1969
My car has a 383 strokes with an Accell HEI distributor and a Summitt brand (made by MSD) box. On the tach out lead, connecting to my tach wire does nothing. I bought a new tach but don't want to smoke it IF the HEiI is killing it. I know many here run HEI and factory techs, what is your secret?
Thanks, Craig
Prepare to be the center of attention when you drive a first generation Camaro. You will be gawked at. Grown men & women will coo like children when you drive past. Children will scream like babies. Dogs & cats will get along. Does it get any better?
Craig1969 is offline
post #2 of 4 (permalink) Old Sep 6th, 15, 09:11 PM
Banned
Chet
Re: 69 Factory tach with HEI ignition
You need to build a tach filter. Search the site for various schematics. I never had any luck. I had to have a modern tach's guts put in my tach. My wasn't an original GM tach, it was OER repop.
onefiness is offline
post #3 of 4 (permalink) Old Sep 6th, 15, 11:56 PM
Steps
I connected up my factory tach to a GM HEI back in the mid 80s pre internet ...simple pull the points.. by pass ign ballast wire... have done some serious mileage, on 3rd Dizzy and never had a problem with the tach... the current dizzy is a Chinese GM copy HEI with copy module.. and no issues
But what is being used here is after market stuff with MSD....
As suggested above...run a forum search on the subject.. and while at it read up on the MSD.. you may end up dropping that and spend a little time on regular car maintenance instead.. reason is explained in old posts on the subject.
Steptoe is offline
post #4 of 4 (permalink) Old Sep 7th, 15, 02:22 AM
69-Pace's Avatar
The filter sticky from the electrical forum...
https://www.camaros.net/forums/showthread.php?t=309026
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
