67 Camaro RS Turn Signal Issue - Team Camaro Tech
post #1 of 5 (permalink) Old Sep 16th, 15, 06:05 PM Thread Starter
Cool 67 Camaro RS Turn Signal Issue
Hey Guys, I was driving my car tonight and noticed my left turn signal was not flashing on the dash, it did however make the blinking sound. Got home and checked everything out. The left rear signals were working fine. The front park lamp housing was not. Replaced the bulb and had no luck. Then checked for voltage at the fuse link feeding the lamp housing, the purple and black wires had no voltage at all. I did check the ground at the lamp housing going to the body and it was tight. Any suggestions? Thanks, Tom
67 Camaro RS Convertible 327 4 speed
Original unrestored, documented 35k Numbers Matching
69 Camaro SS Coupe X55 350/300hp 4 speed
Fully Restored Numbers Matching
1969 Camaro Z28 Restored
351just is offline
post #2 of 5 (permalink) Old Sep 17th, 15, 04:20 AM
Re: 67 Camaro RS Turn Signal Issue
Dash indicator and front turn light are wired together at the firewall.
I assume parking lights work, so socket ground is good.
Only place power comes from is turn signal switch.
Check light blue at steering column as this is going out to light.
Might jiggle handle - pull up.
Everett#2390 is online now
post #3 of 5 (permalink) Old Sep 22nd, 15, 09:06 PM Thread Starter
Are you ready for this..... I took my 67 RS out tonight... The left front turn signal was working fine, including dash indicator light..... I guess something is loose.... I did order a new turn signal switch... I did not check the AIM yet, can I tighten the wires on the turn signal switch without taking everything apart (wheel puller) in the steering wheel? Thx Tom
351just is offline
post #4 of 5 (permalink) Old Sep 23rd, 15, 04:13 AM
69-Pace's Avatar
The parking lamps have a junction in their harness runs as they travel from the valance to the main engine pod. I think it is just before the grommets and the junction is on the underside (at least on 69's) Check the left side for a loose connection at the junction - could explain no voltage. Maybe as it cooled the junction expanded to make a good connection again or you have a frayed or broken wire situation.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #5 of 5 (permalink) Old Sep 29th, 15, 07:49 PM Thread Starter
Problem solved, harness on the firewall was loose... Check another one off the list. Thx Tom
351just is offline
