69 brake light - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 15th, 15, 06:28 PM Thread Starter
robert
69 brake light
All lights work except driver side brake light. Installed new flasher still no light. Any suggestions would be appreciated.
let r eat is offline
post #2 of 5 (permalink) Old Oct 15th, 15, 06:29 PM
Vega$69's Avatar
Re: 69 brake light
Bulb or ground
Vega$69 is offline
post #3 of 5 (permalink) Old Oct 15th, 15, 09:34 PM
Larry
larryh56's Avatar
Re: 69 brake light
Check your ground with a meter
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #4 of 5 (permalink) Old Oct 16th, 15, 09:57 AM
Jeff
yellow69RS's Avatar
Re: 69 brake light
Does the turn signal work on that side? Be sure you have a brake light signal coming out of the T/S switch then trace you way back. It's possible the problem is the T/S switch.
Jeff
yellow69RS is offline
post #5 of 5 (permalink) Old Oct 16th, 15, 10:41 PM
Re: 69 brake light
I had a similar problem last year. Turned out to be a corroded contact in the bulb socket. I replaced the taillight harness. Very simple to change out.
Known to run with scissors....
__________
1969 Camaro Z/28 "clone", GMPP ZZ383, Autogear M22W, Moser 12bolt w/TruTrac 3:73.
Fred Mertz is offline
