67 Camaro RS High Beam Bulb Replacement - Team Camaro Tech
post #1 of 21 (permalink) Old Nov 5th, 15, 05:13 PM Thread Starter
Hey Guys, how easy or hard, is it to replace the high beam bulb (lamp) on the dash cluster. Thx Tom
67 Camaro RS Convertible 327 4 speed
Original unrestored, documented 35k Numbers Matching
69 Camaro SS Coupe X55 350/300hp 4 speed
Fully Restored Numbers Matching
1969 Camaro Z28 Restored
351just is offline
post #2 of 21 (permalink) Old Nov 5th, 15, 05:23 PM
69-Pace's Avatar
Re: 67 Camaro RS High Beam Bulb Replacement
Its not horrible once you get the cluster off/out. I think two screws hold the light and bulb in the pocket. See photos.
Both 67 & 68 (but 68 photo) Highbeam indicator pocket is noted by red arrow.
1967
And for reference for 68 owners
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 21 (permalink) Old Nov 5th, 15, 05:30 PM Thread Starter
Brian, I removed 7 screws, the speedo cable, and tach cable. It pops out about a half inch. Not coming out. Did I miss something? Thx Tom
351just is offline
post #4 of 21 (permalink) Old Nov 6th, 15, 07:57 AM
Michael
You have to drop the steering column before you can hope to remove the instrument cluster (if that's your goal).
Remove the 4 small screws that attach the 2 piece steering jacket beauty trim to the steering column. Then remove the 3 nuts that support the steering column. Next, gently pull the steering column down far enough to wriggle the instrument cluster from the dash (sounds like you've already removed everything from the backside of the cluster).
Actually, if you just want to swap the hi-beam bulb out, it's got it's own socket at the very top of the cluster. Just fish behind the top of the cluster and pop out the socket and replace the bulb.
On original clusters, I usually find that if you try to remove the screws holding the hi-beam housing from the plastic cluster, the plastic cluster screw points break (they are pretty old if you think about it).
mahunt is offline
post #5 of 21 (permalink) Old Nov 6th, 15, 05:32 PM Thread Starter
Michael, I am a little lost. I have spoken to several folks about replacing the high beam bulb. They have said the cluster must be removed before you can replace the bulb. I like your suggestion, reaching behind. I am going to try it.. How much success have you had in the past with the reach behind method. Thx tom
351just is offline
post #6 of 21 (permalink) Old Nov 6th, 15, 06:51 PM
69-Pace's Avatar
Been a long time since I pulled one out of a 67 or 68. DO you have enough room to shine a light behind to see whats binding. Don't remember if they had already dropped the column.
69-Pace is offline
post #7 of 21 (permalink) Old Nov 19th, 15, 03:58 PM Thread Starter
Hey Guys, first of all I would like to thank everyone who responded to my post. I dropped the steering column and the cluster came right out (very simple). Next, I removed the ground clip from the high beam post and it snapped, WTF. Then I purchased two nos ground straps. One a 67, the other a 68. Guess which one I installed, the thicker 68. I have several additional issues. Will post in next tread.
ID:	129465   Click image for larger version
351just is offline
post #8 of 21 (permalink) Old Nov 19th, 15, 04:41 PM Thread Starter
Hey Guys, after checking the back of the cluster, I noticed a black bulb holder missing for the low fuel light. No big deal, I ordered a used oem one on line with new bulbs. Then I checked the bottom of the black dash carrier, it had a small piece that was cracked and then it popped off, WTF. I did find a used oem one in nice shape. The whole process it beginning to turn into nightmare. All for a high beam bulb.
ID:	129489   Click image for larger version
351just is offline
post #9 of 21 (permalink) Old Nov 19th, 15, 09:47 PM
George
Your 67 has a low fuel light in the dash?
carbuff67rs is offline
post #10 of 21 (permalink) Old Nov 20th, 15, 02:05 AM
69-Pace's Avatar
Most projects have some mission creep. You might consider just running some wire from the top of the cluster housing from the bolt that would hold down the optional speed warning module then screw the other end of the wire to the dash support metal and have a stable working ground. There are a few threads on doing this to avoid issues with the paperclip.
69-Pace is offline
post #11 of 21 (permalink) Old Dec 2nd, 15, 08:22 AM Thread Starter
Hey Guys, here is the 411 on my 911. I installed the courtesy lights, everything was ok there. Not sure if they are in the exact location under the dash, no biggie. Now for the my major issue. When I re-insatlled the dash cluster, major issues occurred. The turn signals are on all the time, I ran another ground to the dash from the cluster (I have a good ground for sure). So then I removed the cluster from the dash and checked the circuit board. First I checked continuity, all good and then I ran 12vdc. Everything works well. Then I plugged the harness in the cluster. Same thing transpired, turn signals are on all the time (not blinking), I am thinking ground issue. Also the head lights will not come on with the harness unplugged or plugged. Checked the fuses on the drivers side floor, everything fine there. Any suggestions. Thx Tom P.S. All for a high beam lamp.
351just is offline
post #12 of 21 (permalink) Old Dec 2nd, 15, 10:22 AM
Nick
make sure your 4 way flasher is not on, and move the wires behind the headlight switch see if they go on
67 rs/ss 350 original eng,700r4, a/c, tilt, deluxe int,strato bench,Ca.emission,front disk,am/fm,floor clock,17" W/V Ralleys,Toyo T1S 255/40/17, 245/40/17
MRCOOL_RSSS350 is offline
post #13 of 21 (permalink) Old Dec 2nd, 15, 01:55 PM Thread Starter
Hey Nick, four way flasher is off and I tested the headlight switch, everything good there.
351just is offline
post #14 of 21 (permalink) Old Dec 16th, 15, 06:43 PM Thread Starter
Hey Guys, wanted close this thread on a positive note. The first issue I had was the turn signals not blinking after I re-installed the dash cluster. The problem was a loose pin on the turn signal switch connector at the bottom of the steering column (see pic). The second issue was my headlights were not coming on. I resolved that issue also. I had a bad ground under the wheel well. I went on line and ordered a large colored wiring diagram for my RS (see pic). With that being said, it was game on and my problems were solved in no time with my multi meter.
ID:	131417   Click image for larger version
351just is offline
post #15 of 21 (permalink) Old Dec 16th, 15, 07:07 PM Thread Starter
Wanted to add one more thing to this thread. I looked over my new wiring diagram, then made sure all my grounds were tight, secure, and clean. Also went thru all the electrical connections, relays, fuse panel, etc. I cleaned everything up with contact cleaner, brass brush, and added di-electric grease. I wanted to thank everyone who helped me change my high beam bulb (lol). It was a nightmare at first, but in the end I learned a lot and resolved the issues. Thx again, Tom
351just is offline
Tags
67 68 high beam indicator
