1969 Camaro Big Block starter issues - Team Camaro Tech
post #1 of 8 (permalink) Old Nov 20th, 15, 08:10 PM Thread Starter
Larry
Do not have trouble starting car when cold but after warmed up, starter does not seem to engage. When I let car cool down, it starts fine. Thoughts?
Herlola is offline
post #2 of 8 (permalink) Old Nov 20th, 15, 08:51 PM
Re: 1969 Camero Big Block starter issues
Sounds like you have headers. Either make a heat shield for the starter or get some header wrap or starter wrap. http://www.chevyhardcore.com/news/ne...tarter-shield/
COPO is offline
post #3 of 8 (permalink) Old Nov 21st, 15, 12:50 AM
Doug
If you don't have a hi-torque mini starter you might want to invest in one. Another thing check your initial timing to see if it is to high. Most of the time just back of 2 degrees.
Cdminter55 is offline
post #4 of 8 (permalink) Old Nov 21st, 15, 07:18 PM Thread Starter
Larry
Thanks for suggesting. I have ordered one.
Herlola is offline
post #5 of 8 (permalink) Old Nov 21st, 15, 07:19 PM Thread Starter
Larry
Thanks for input. Will look at timing and get high torque starter.
Herlola is offline
post #6 of 8 (permalink) Old Nov 21st, 15, 09:39 PM
Make sure your battery is big enough and in good shape for the application first!
Mostly Camaros and FINALLY a Double Nickel
Yellow69RSZ is offline
post #7 of 8 (permalink) Old Nov 22nd, 15, 05:46 AM
As well as battery cables (min 1 AWG) are in good condition - no clamp-on clamps - and their connection points are clean/wire brushed, and alternator is charging the battery fully.
post #8 of 8 (permalink) Old Nov 22nd, 15, 06:21 AM
DT
Donny
DT's Avatar
Re: 1969 Camaro Big Block starter issues
As mentioned above. Make sure Batt is fully charged and in good working order. Check all wire connections. Where is your ground ?? On top of alt bracket ?? Make sure the ground is making good contact. Ground connection to pass fender ?? What is your timing set at ??
DT is offline
