67 Camaro 350 Temp idiotlight not working - Team Camaro Tech
post #1 of 4 (permalink) Old Dec 6th, 15, 02:44 PM Thread Starter
I have replaced the dash temp bulb, tried grounding the wire, cannot get the bulb to light. The car is all stock and wiring looks to be in excellent condition. Any thoughts or suggestions?
68 Camaro RS/SS Convertible L34 396/350 Original/Stock
67 Camaro RS/SS Coupe 350/295 Original/Stock Hi Optioned
71 Challenger Convertible 318 Original/Stock
70 Cuda 440-6 Barrel Coupe Factory AC
Stingray_RSSS is offline
post #2 of 4 (permalink) Old Dec 6th, 15, 05:21 PM
George
Re: 67 Camaro 350 Temp idiotlight not working
Im assuming you had the key in the run position and then grounded the green wire under the hood?
carbuff67rs is offline
post #3 of 4 (permalink) Old Dec 6th, 15, 07:22 PM
George
Wait, this car is an ss350? Does it have factory gauges? If so, Im not sure it has a functioning temp light.
post #4 of 4 (permalink) Old Dec 6th, 15, 07:31 PM
69-Pace's Avatar
Yes sting -
If it is a gauge sender you can test Ohm's when grounded.
A warning light switch will have only two states open and closed circuit for a bulb. You can also detect activity with the meter if the fuse is dead or the wiring interrupted in route through the bulkhead connection to the switch.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
