69 Camaro Optima battery mounting - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 12th, 15, 02:51 PM Thread Starter
Installing an 8002 Grp 34 Optima red top battery in a stock battery tray. They say to use the bottom spacer, but then the tray lip is too low to hook on the battery. Without the bottom spacer the tray lip works, but then the scew down clamp does not work as it is too high. Tried the red spacer they provided, but that does not work either. Other than fabricating my own screw clamp, is there a better solution? thanks
domo69 is offline
post #2 of 5 (permalink) Old Dec 12th, 15, 05:14 PM
Re: 69 Camaro Optima battery mounting
throw the Optima a way use a real battery
john68 is offline
post #3 of 5 (permalink) Old Dec 12th, 15, 06:49 PM
Rick
My group 34 Optima worked great no spacer? On it's 4th year.
69 COPO clone, 461" BBC 11.25:1 Compression
840 Rec Heads (2.25/1.88) AED 850 HO carb
Orig Exhaust Manifolds
Straub (Clay Smith) cam, 288/300 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is online now
post #4 of 5 (permalink) Old Dec 12th, 15, 08:16 PM
ZZ_430's Avatar
Every Optima I've seen for years now includes the correct hold down clamp and will fit the stock tray no problem.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #5 of 5 (permalink) Old Dec 12th, 15, 09:16 PM Thread Starter
did you just use the original clamp? When I tried that, as I tightened up the screw the clamp side raised up off of the battery...
domo69 is offline
