Wiper switch or Motor - Team Camaro Tech
post #1 of 4 (permalink) Old Jan 22nd, 16, 07:59 PM Thread Starter
Bryan
Hello all,
It is time for me to get my car inspected and I am having a problem with my wipers. When I turn the wiper switch on low or high the wipers do not work, when I turn the wiper switch on low or high and push it in the wipers work only on low speed. I am pretty sure it is the switch or the wiring. What do you all think? Any help on the schematics or switch knowledge is appreciated. Thanks
68 Camaro SS
468 VortecPro
M22 Rockcrusher
bhodges061 is offline
post #2 of 4 (permalink) Old Jan 23rd, 16, 06:45 AM
Re: Wiper switch or Motor
Its either the switch or a bad ground. There is a metal strap looking thing that attaches to the switch with a small black wire that attaches to the dash carrier. Thats the ground strap. If it's a bad ground maybe by you pushing in on the switch it is making a partial ground and you get low speed. I would check that ground first.
BRICO69 is offline
post #3 of 4 (permalink) Old Jan 23rd, 16, 10:51 AM
Jeff
yellow69RS's Avatar
Wiper Bench test diagram courtesy of Kevin W
https://www.camaros.net/forums/showthread.php?t=42420
Any questions just ask. I'm leaning towards a wiring problem at the motor but using the bench test procedure will narrow it right down.'
Jeff
yellow69RS is offline
post #4 of 4 (permalink) Old Feb 1st, 16, 06:41 PM Thread Starter
Bryan
Thanks for the help the switch needed to be replaced and it was having trouble grounding on the back of the dash. Cleaned the dash behind the switch and it works great.
