Trunk Battery Ford Solenoid Wiring Question - Team Camaro Tech
post #1 of 18 (permalink) Old Feb 18th, 16, 03:39 PM Thread Starter
david
Send a message via AIM to kabinet Send a message via MSN to kabinet
Putting my Optima in the trunk for my LS3 swap. I put a Ford solenoid with it so I don't have a hot 1/0 gauge in the event of an accident or something. I asked a question about the size of the charge wire from the 150amp alternator back to the battery (this chart says use 0 gauge), most people use 8-6ga and ilikeike suggested 4 gauge if I was going to put amps and whatnot in the trunk (I am). But doesn't this kinda defeat the purpose of the Ford solenoid by having a large gauge hot wire?
kabinet is offline
post #2 of 18 (permalink) Old Feb 18th, 16, 04:05 PM
Re: Trunk Battery Ford Solenoid Wiring Question
If you use proper installation techniques you don't need the Ford relay. If you look at the way BMW and Volvo install their rear mounted batteries, you'll find that they run the cable directly from the battery through the interior of the car to a binding post in the engine bay. The cable is adequately shielded and protected by sheathing. I worry about the 10+ gallons of extremely flammable liquid I have in a metal tank in the rear of my car.
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #3 of 18 (permalink) Old Feb 18th, 16, 04:20 PM
Use a fuse or circuit breaker in line
68 Camaro~LSx ~all motor
post #4 of 18 (permalink) Old Feb 18th, 16, 05:36 PM
Garth
Yes!
With a 150amp alternator you should use a 6ga minimum for it work properly. Use a circuit breaker or fuse at the battery for the main feed wire. Any short will trip that. Any damage done with a 6ga wire will just as bad as a 1/0ga wire, either one will start a fire. And you have less wires and weight to deal with.
My new gen5 Camaro has the battery in the spare tire well and no Ferd solenoid anywhere to be found. That's 'factory'.
1969 Camaro SS 350 LeMans Blue
2015 Z/28 - Red
2 x 1967 R/Tís
1977 Power Wagon
1978 Liíl Red Express
69L48Z27 is offline
post #5 of 18 (permalink) Old Feb 18th, 16, 05:45 PM
Rick
The solenoid is not intended for constant on. It will not last.
69 COPO clone, 461" BBC 11.25:1 Compression
840 Rec Heads (2.25/1.88) AED 850 HO carb
Orig Exhaust Manifolds
Straub (Clay Smith) cam, 288/300 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is offline
post #6 of 18 (permalink) Old Feb 18th, 16, 05:47 PM
Garth
Solenoid is only on when cranking.
2015 Z/28 - Red
2 x 1967 R/Tís
1977 Power Wagon
69L48Z27 is offline
post #7 of 18 (permalink) Old Feb 18th, 16, 05:50 PM Thread Starter
david
I was going to use the solenoid only when cranking so my 1/0 gauge would only be hot then but I would still have a hot 4 gauge from the alternator back to the battery. It will definitely save a lot of hassle routing all the wires back to the trunk if I don't use the Ford solenoid.
kabinet is offline
post #8 of 18 (permalink) Old Feb 18th, 16, 07:44 PM
Vega$69's Avatar
you don't need 4 ga from the alt to the battery for charging.
I run a #10 with fusible link. Lots of cars done that way and never an issue. I run AC, Amps with subs etc.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #9 of 18 (permalink) Old Feb 18th, 16, 07:57 PM
I did mine w/o the Ferdnoid - ran a 1/0 pos battery cable through the interior to a bulkhead connector under the heater box. Charge wire connects there - pos cable serves doubly duty as the charge wire from there to the batt
BPOS is offline
post #10 of 18 (permalink) Old Feb 19th, 16, 03:45 AM
look at Mad Elec.
BigVin is offline
post #11 of 18 (permalink) Old Feb 19th, 16, 03:50 AM
he also has all the parts to do the job call him nice guy 559 539 7128
BigVin is offline
post #12 of 18 (permalink) Old Feb 19th, 16, 08:09 AM
Rick
Ok I misunderstood what you were trying to do.
rp930 is offline
post #13 of 18 (permalink) Old Feb 19th, 16, 08:23 AM
George
Gbauer's Avatar
At which end, though? At the battery or alternator? Or both?
I'd be tempted to do both only because if the wire chaffs and shorts out either end would need a fuse to prevent a fire.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #14 of 18 (permalink) Old Feb 19th, 16, 08:43 AM
Use proper wiring techniques and you will not have any chafing. Don't run the wire over any sharp edges, don't stretch it tight, use plenty of sheathing, etc.
If you are in a wreck so violent that the insulation of a well protected slack wire running through the interior of the car is compromised, your battery has been destroyed in the process.
post #15 of 18 (permalink) Old Feb 19th, 16, 10:00 AM
Darin
ilikeike's Avatar
just 1 amp that I'll be using (when I get around to it)requires a 4g or larger to power it.
I ran a real 4000w in my wakeboard boat, and ran 1/0 from the alt to the battery bank to keep up.
I doubt I'll run anything I put in my camaro that hard,but I do have the gear sitting around so I may aswell use it. Also my friend is on the design team for Arc Audio,he'd give me sh!t if I didn't run his equipment to their standard.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
