Louder horn needed - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 1st, 16, 06:07 PM Thread Starter
Kevin
Louder horn needed
My horn sounds pretty pitiful- what do you guys have? Would like ti to be able to be "plug and play" into existing wires.
Thanks!
Kev68ss is offline
post #2 of 6 (permalink) Old Mar 1st, 16, 06:22 PM
kevin
Re: Louder horn needed
Amazon.com: Wolo (419) Bad Boy Air Horn - 12 Volt ...
www.amazon.com/...Bad-Boy-Horn/dp/B000F5DQW...
Amazon.com, Inc.
Rating: 4 - ‎696 reviewsSave Big On Open-Box & Used Products: Buy "Wolo (419) Bad Boy Air Horn - 12 Volt” from Amazon Open-Box & Used and save 61% off the $77.99 list price.
flat tire is offline
post #3 of 6 (permalink) Old Mar 1st, 16, 09:20 PM
George
You might try giving the horn a wack with a wooden block. off the car of course. Sometimes that can loosen any corrosion or bug nests that may have caused an issue. You can get a pair of horns off of an 80's camaro or firebird for cheap on ebay. They will usually bolt in place fairly easily.
Something like this.
http://www.ebay.com/itm/77-81-Camaro...BWKXPG&vxp=mtr
carbuff67rs is offline
post #4 of 6 (permalink) Old Mar 1st, 16, 09:41 PM
George
post #5 of 6 (permalink) Old Mar 2nd, 16, 04:48 AM
Kevin
KevinW's Avatar
Likely the horns maybe some rust in them. Spray wd-40 down the bell, rotate them to get wd-40 into the core, reverse direction to get it out. light whacks with plastic hammer, then retest. Make sure you have a GOOD ground. Low notes go bad 1st.
Kevin
KevinW is offline
post #6 of 6 (permalink) Old Mar 2nd, 16, 05:00 AM
Steiner
Fairly cheap $30 hi/lo set of Blazers off the shelf at AutoZone. 112db. Spade connectors and come with mounting hardware.
'69 Camaro
500hp/538lbft
Steiner is offline
