Radio antenna - Team Camaro Tech
post #1 of 2 (permalink) Old Mar 23rd, 16, 09:45 AM Thread Starter
Kevin
Radio antenna
I recently purchased a 67; by its options code(s), it had a right rear antenna from the factory, and assumed an AM radio. One of its past owners has either sealed up the antenna hole (haven't crawled inside the trunk to look). In any event, I don't plan to reinstall this antenna, but rather use one that can install under the dash. Does anyone have any recommendations for one of these "hidden" type antennas? I used to have one in a Harley (Dresser). It worked fairly well, except for the fact at highway speed, I could not hear anything over the wind noise anyhow.
Never argue with an idiot; they'll only drag you down to their level, then beat you with experience.
bucko is offline
post #2 of 2 (permalink) Old Mar 24th, 16, 03:51 AM
69-Pace's Avatar
Re: Radio antenna
Pull a search as there have been several threads on antenna options, hidden, power and original mast.
here are a few:
https://www.camaros.net/forums/gtsear...543j2769063j25
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
