Back of instrument cluster short - Team Camaro Tech
post #1 of 11 (permalink) Old Apr 3rd, 16, 05:46 PM Thread Starter
Went to change the alternator warning light bulb and found this. So, how bad is this and what are my options? Want to keep as original as possible.
1967 RS Camaro, L30/M20, 12 bolt rear, Quadrajet, Breakerless SE ignition.
duly is offline
post #2 of 11 (permalink) Old Apr 3rd, 16, 06:04 PM
69-Pace's Avatar
Re: Back of instrument cluster short
If it is just on the printed circuit you can replace it super easy.
The reproductions available are on a modern Mylar that resists cracking with age.
My question would be what caused the damage in the first place.
Is there something added behind the cluster that is chaffing against it?
Whats that under the circuit board - black in the area of the damaged line?
If the cluster housing is damaged it can be ground smooth and the sharp edges abated so it won't damage the new board.
A piece of aluminum tape can also seal the surface if conducting is needed.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 11 (permalink) Old Apr 3rd, 16, 06:28 PM
Jeff
Looks like an old repair
Jeff
- 400 Dart Little"M", SRP 10.2:1, 4340 Scat rotating Assy, Solid Roller, AFR 210 Eliminators, Jesel shaft rockers,Super vic, Prosystems 847CFM, Tko600, 12 bolt 4:10 Eaton posi W/ Strange Hy-Tuf race axles and eliminators.
Best E.T. (11.96 @ 118.06) N/A
Classic Copper 4 Spd
jcdubs is offline
post #4 of 11 (permalink) Old Apr 3rd, 16, 07:24 PM Thread Starter
It is an old repair. Good ol PO decided to patch it with some electrical tape and did not attempt to fix the problem the correct way. Makes me wonder what else has been done/messed up to this 20,000 mile car. Time to order a new board.
Thanks fellas
duly is offline
post #5 of 11 (permalink) Old Apr 12th, 16, 06:43 PM Thread Starter
Ok got the new circuit board put in. All the lights are working but the alternator warning light still is not. I also checked the voltage coming out of the 2 part connector going to the light socket and I am getting 7.5 volts. Here is the socket. Is this the correct socket and did all 1967 Camaros have idiot warning lights? And this is the 2 part piece I am talking about. When I say 2 piece you can see the black piece fits into another coming out of the wire loom in the dash.
duly is offline
post #6 of 11 (permalink) Old Apr 12th, 16, 07:16 PM
Vega$69's Avatar
is the bulb good and is it the correct bulb?
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #7 of 11 (permalink) Old Apr 12th, 16, 07:41 PM Thread Starter
Nevermind, sorry for posting before I looked at my service manual more thoroughly. The light I am talking about is my fuel light. I have no alternator warning light. Lesson learned, look in the book first.
And yes the bulb is good, gotta run the tank low before I know if it works I guess.
duly is offline
post #8 of 11 (permalink) Old Apr 12th, 16, 10:03 PM
69-Pace's Avatar
if you have a radioshack potentiometer 0 to 100 ohm's can be simulated to the low fuel warning module to trigger the unit. A 1967 unit sends power over the yellow when the trigger point is reached, 68/69 send ground..
69-Pace is offline
post #9 of 11 (permalink) Old Apr 13th, 16, 10:34 AM
Jeff
yellow69RS's Avatar
Glad you determined it's not the alternator light. The alternator light has to have two wires.
Jeff
yellow69RS is online now
post #10 of 11 (permalink) Old Jun 7th, 16, 10:12 PM
I have the same exact short! Any resolution to this problem? Don't want to put in a new circuit board and burn it up. How can I test before install new board?
Thanks,
Chris
C-DUB is offline
post #11 of 11 (permalink) Old Jun 8th, 16, 03:42 AM
Kevin
Thanks fellas
The amount of PO electrical fixes I found when chasing electrical faults in my 67 were down right scary. I found cut, and twisted together wires sealed with scotch tape; I found extension cord wiring used to connect a voltage gauge; and the best: I found the low/high beam floor switch replaced with a house light switch!
Never argue with an idiot; they'll only drag you down to their level, then beat you with experience.
bucko is offline
