Hot positve cable on battery - Team Camaro Tech
post #1 of 10 (permalink) Old Apr 14th, 16, 10:40 AM Thread Starter
Lee
LeeC's Avatar
I took the Camaro out today ( first run on new motor) and when I stopped by a buddy of mine I shut it off, and needless to say he wasnt home. So, when I went to start it wouldnt start, slow turn over, and when I went to check the battery cables I burnt my thumb on the positive cable.
What could be the cause of this?
1969, X-11
383 5 speed, 373 rear
LeeC is offline
post #2 of 10 (permalink) Old Apr 14th, 16, 10:47 AM
Steiner
Re: Hot positve cable on battery
The starter draws over 200A initially and then maybe around 100A. The more the starter turns, the higher the draw as the windings heat up. All that is going down that cable from your battery positive and the cable starts to act near about like a stove element. If you've got a stock style starter you may want to consider a PMGR one. They rely on gearing instead of brute force so they draw a good bit less and typically output more.
'69 Camaro
500hp/538lbft
Steiner is offline
post #3 of 10 (permalink) Old Apr 14th, 16, 11:05 AM
Also, it can mean a dirty/corroded junction between clamp and post.
Might be a good time to remove clamps and clean posts and clamps.
Resistance creates heat
Everett#2390 is online now
post #4 of 10 (permalink) Old Apr 14th, 16, 03:41 PM
Yep, most likely dirty/loose/corroded connection.
dhutton is offline
post #5 of 10 (permalink) Old Apr 14th, 16, 03:45 PM Thread Starter
Lee
LeeC's Avatar
Nope, not dirty or loose connection. Just put battery in.
1969, X-11
LeeC is offline
post #6 of 10 (permalink) Old Apr 14th, 16, 04:17 PM
What is the voltage on the battery with and without the car running?
dhutton is offline
post #7 of 10 (permalink) Old Apr 14th, 16, 04:32 PM Thread Starter
Lee
LeeC's Avatar
12 and 14.4
1969, X-11
LeeC is offline
post #8 of 10 (permalink) Old Apr 14th, 16, 06:13 PM
How long were you cranking it before you touched the cable? Sounds like Steiner was right.
dhutton is offline
post #9 of 10 (permalink) Old Apr 14th, 16, 08:13 PM Thread Starter
Lee
LeeC's Avatar
Not sure but seems fine now
1969, X-11
LeeC is offline
post #10 of 10 (permalink) Old Apr 14th, 16, 11:18 PM
Larry
larryh56's Avatar
The size of the cable can make a big difference even if it is new and clean. What size battery cables are you using?
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
