Fan relay install question - Team Camaro Tech
post #1 of 10 (permalink) Old Apr 23rd, 16, 06:54 PM Thread Starter
Rich
rico6983's Avatar
I am 95% finished with my AAW complete auto harness install. The last big piece is installing the fan relay. I ordered the relay kit from AAW and the instructions aren't simple enough for me to understand apparently. In order for the relay to work, it says to connect it to the electric fan sending unit. I've looked on my engine and I don't see the sending unit installed so I guess I need to get one of those. Is there a preferred place to get one? I looked on rock auto and didn't find one. I'm also not 100% sure where to put it. I'll post pics of 2 places of where it might go if someone can tell me if it's good.
On another note, I have a connection coming from the alternator and not quite sure what connects to it. I have added a picture of this as well. Thanks in advance for any assistance. I've been trying to be very patient with this install. Let's just hope it all works haha!
ID:	145977   Click image for larger version
Name:	add sensor.jpg
ID:	145985   Click image for larger version
rico6983 is offline
post #2 of 10 (permalink) Old Apr 23rd, 16, 10:54 PM Thread Starter
Rich
rico6983's Avatar
Re: Fan relay install question
Apparently my alternator is a 1 wire alternator and does not require me to plug this extension in. If I do plug it in, I don't know if it will affect anything. The brown wire goes back to the fuse harness so I imagine that just goes to the dash. Please correct me if I'm wrong and let me know if I should just disconnect this extension all together.
rico6983 is offline
post #3 of 10 (permalink) Old Apr 24th, 16, 07:08 AM
George
Gbauer's Avatar
1) you don't have an electrical sending unit for your temp sensor. That's a mechanical.
2) that pigtail allows your dummy light to work when connected.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #4 of 10 (permalink) Old Apr 24th, 16, 08:45 AM
Jeff
yellow69RS's Avatar
I could be mistaken but I think that alternator is external regulator with a plug that is like this [ll]. the plug shown is for an internal regulated alternator.
Jeff
yellow69RS is offline
post #5 of 10 (permalink) Old Apr 24th, 16, 10:25 AM Thread Starter
Rich
rico6983's Avatar
I know I don't have the sending unit installed, if I do get one, where should I install it? Here is one that rick's Camaro sells. Will this work?
Camaro Electric Cooling Fan Temperature Sending Switch, 1967-1985
rico6983 is offline
post #6 of 10 (permalink) Old Apr 24th, 16, 10:53 AM
Vega$69's Avatar
I would use something like this. It has adjustable temp range
Derale Performance Deluxe Adjustable Fan Controllers with Radiator Probes 16759 - Free Shipping on Orders Over $99 at Summit Racing
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #7 of 10 (permalink) Old Apr 24th, 16, 11:39 AM Thread Starter
Rich
rico6983's Avatar
My car is generally a weekend warrior for just driving around town. I don't plan to race or anything like that. I will look into getting an adjustable controller just to be on the safe side.
rico6983 is offline
post #8 of 10 (permalink) Old Apr 25th, 16, 12:15 AM
Larry
larryh56's Avatar
The 2 wires on the plug are for the voltage sensing wire and dash light. I personally would get a 3-wire internally regulated alternator and use those wires. This will allow your alternator to put out more power when the voltage drops. The head between 1 & 3 is generally where the sender for the temperature gauge goes and don't use Teflon tape on it. You can put the electric fan temperature sensor where the gauge sensor is now.
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #9 of 10 (permalink) Old Apr 25th, 16, 05:48 AM
Vega$69's Avatar
You can use this controller if you wan the threaded sender instead of the probe
Derale Performance Deluxe Adjustable Controllers with Pipe Threaded Probes 16749 - Free Shipping on Orders Over $99 at Summit Racing
You can use Teflon tape per the instructions
Vega$69 is offline
post #10 of 10 (permalink) Old Apr 25th, 16, 06:15 AM Thread Starter
Rich
rico6983's Avatar
I started looking at the 10SI 3 wire alternators. I'm not sure what would be the best for me. I have a radio with alpine speakers and that's the only thing that would require a little more power. My battery has been dying a lot if I don't run the car often so maybe getting a new one is something I should have done a while ago. Any suggestions? Thanks for all the input.
rico6983 is offline
