67 Camaro Dash Turn Signals - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 29th, 16, 08:18 PM Thread Starter
Vinny
I just put in a new tach and put the dash together for the third time. Here's the issue, the signals work on the outside of the car, but are not working in the dash (those green arrows). The Tach, and Brake light works. Please help...
Vinny
VinnyCamaro is offline
post #2 of 4 (permalink) Old Apr 29th, 16, 08:37 PM
Re: 67 Camaro Dash Turn Signals
Maybe a blown fuse or something?
peter123wallace is offline
post #3 of 4 (permalink) Old Apr 29th, 16, 08:43 PM
69-Pace's Avatar
Check two things.
First the ground of the cluster which is achieved by the "paper-clip" at the screw by the high-bream indicator.
Second make sure the ribbon connector is right and tight on the printed circuit board.
Ground issues are the most common issue for weird cluster functions. You can and maybe should like so many others with 67, and 68's add a real ground wire from the cluster using one of the screws on the back lower left and then connect the ground to knows good point behind the dash. Check the sticky in the electrical section how to fix your dash lights. https://www.camaros.net/forums/19-ele...step-step.html
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #4 of 4 (permalink) Old May 2nd, 16, 03:16 AM
Kevin
And not to overlook the obvious, check the bulbs themselves. Anytime I have a cluster out for diagnosing an issue, I put in brand new bulbs if they are a year or more old.
Never argue with an idiot; they'll only drag you down to their level, then beat you with experience.
bucko is offline
