'69 Factory Tach Test - Team Camaro Tech
post #1 of 3 (permalink) Old May 29th, 00, 05:32 PM Thread Starter
BUD
Does anyone know how to check a tach out to see if it works before installing in the dash?
BUD is offline
post #2 of 3 (permalink) Old May 30th, 00, 06:43 PM
I'm having the same problem. Just bought an original tach for a 69 and installed it in the dash and it does nothing. Checked the wiring with a dwell meter and everything seems fine. I guess I'll have to remove it and hand wire it up. If anyone knows how to test one to make sure it's working please respond. Thanks
Black69 is offline
post #3 of 3 (permalink) Old Jun 6th, 00, 06:24 PM
I checked mine (68) by running a lead from the negative side of the coil to the "tach" signal input to the the tach Battey + to the b+ part of the tach and grounding the base. Worked great. Hope this helps-Dan in WV
68rally is offline
