Figuring out what alternator I have??? - Team Camaro Tech
post #1 of 11 (permalink) Old Mar 14th, 05, 05:32 PM Thread Starter
I bought my car with a delco remy alternator already on it. Im trying to figure out if its externally regulated or if its a internal. The only numbers on it are 9129-12VNEG The back of the case has 12-4 on it. It has the R-F plug and a battery and ground terminal. Please help me figure out what I have.
69CamaroChesapeakeVA is offline
post #2 of 11 (permalink) Old Mar 14th, 05, 06:31 PM
Harry
dawg's Avatar
on the drivers side radiator support is there a box with electrical connectors going to it?
if so its externally regulated.
if your inclined to convert it here is a link:
https://www.camaros.net/techref/ftecref14.html
434 stroker
US Navy retired
dawg is offline
post #3 of 11 (permalink) Old Mar 15th, 05, 01:21 AM Thread Starter
The voltage regulator was not there, but the wiring was not converted over either. I just need to figure out what type of alternator this is so I can go ahead and convert over the wiring.
post #4 of 11 (permalink) Old Mar 15th, 05, 05:16 AM
Guess
HwyStarJoe's Avatar
Does this help?
https://www.camaros.net/cgi-bin/forum...9.html?#000001
HwyStarJoe is offline
post #5 of 11 (permalink) Old Mar 15th, 05, 10:55 AM Thread Starter
that helps alot. thanks guys
post #6 of 11 (permalink) Old Mar 15th, 05, 12:53 PM
If the connector on the alternator is like this: II it's external
If it's like this: - - it's internal
post #7 of 11 (permalink) Old Mar 15th, 05, 05:28 PM Thread Starter
looks like mine is a external. DAGGGGG. Think Im taking a trip to autozone soon to find a internal. Anyone know of any models that will work.
post #8 of 11 (permalink) Old Mar 15th, 05, 06:55 PM
any will work, but it ain't automatic, unless you get a one wire, and some have had trouble with those, also a one wire would kill your gen light if you care.
To use an internal, you need to switch the connector that plugs into the alternator, and put a bypass plug on the connector for the regulator. (it's 4 wires in a row, and flat) These parts are readily available, I think Ricks even has. Also check out madelectrical.com
post #9 of 11 (permalink) Old Mar 21st, 05, 05:49 PM Thread Starter
Ive already wired the car Via Dave Possi's website for the voltage regulator. I just need to know what car to use when I ask my local autozone guy for the internal alternator.
post #10 of 11 (permalink) Old Mar 22nd, 05, 02:35 PM
hmmm, how bout a 75 monte carlo?
post #11 of 11 (permalink) Old Mar 22nd, 05, 05:10 PM Thread Starter
I'll have to give that a try
