1991 power locks - Team Camaro Tech
post #1 of 2 (permalink) Old Mar 31st, 04, 04:47 AM Thread Starter
Weston
Westonz28's Avatar
New driver Camaro 1991 Conv. Power door locks do not work. I checked the fuses and could not fine a bad one any guess why it will not work.
1967 RS L30/M20 2nd owner numbers matching
1968 Z28 Butternut Yellow original BU rear end
1968 SS/BB 396, Daughters Camaro BB not numbers matching.
1968 Coupe 2nd owner Sons Camaro numbers matching
1969 RS LM1 2nd owner numbers matching
1966 Chevy II SB 400 alum trick flow heads, Turbo 400, Dana 44 rear
1970 Camaro coupe, 350 L65, 350 auto, numbers matching,
1968 Chevelle Malibu, 327 L30, 3 speed on the tree, third owner.
1941 Ford Super Deluxe Coupe
1968 SS El Camino BB
Westonz28 is offline
post #2 of 2 (permalink) Old Mar 31st, 04, 06:18 AM
Thumbs up
Usually is the driver's door switch will corrode within. Replacement is needed. Same goes for pass side.
Go back to fuse and measure voltage on the two spots of the fuse on either side of the number stamped on the fuse. If no power for either terminal, then a fusible link at starter or battery is blown.
