no break or rear hazard lights - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 15th, 05, 06:52 PM Thread Starter
I have all lights except break and rear hazard lights.
they are both on the same circuit? Dont know if its the hazard warning sw or light sw. Any help would be nice. Hard wired stop lamp sw wiring orange to white, have 12V. Not getting voltage on brown out of light sw to rear.
67davecamaro is offline
post #2 of 4 (permalink) Old Feb 16th, 05, 02:20 AM
Brown is tail/license light. Y is Yellow for
left turn/brake light. DG is dark green for right turn/brake light. Brown from headlamp switch.
DG & Y come from turn signal connector after the left driver kick panel connector. If fuel gauge, tailights work, then can assume(?) this connector is okay.
White wire from brake switch goes to Haz sw, the end terminal of the steering column connector. Haz sw parallels lt & rt turn signals, same circuit for brake lights. Haz sw off, both brake on until turn sig is selected. Then power from t/sig to either selected circuit, ie, DG for rt turn/brake, Yellow for left turn/brake.
Welcome to the Club! Clear as mud, ay?
post #3 of 4 (permalink) Old Feb 16th, 05, 05:46 PM Thread Starter
Everett#2390 thank you very much for your help. Should have known that the brown went to all of the lights in the rear. I jumped into the hazard switch and found the two brass pieces on the turn signal cam, I only put springs back on one of them. Put springs back on the other brass piece and got rear hazards and break lights. Dont want to tell put some one else might do the same. Again thank you.
post #4 of 4 (permalink) Old Feb 17th, 05, 02:14 AM
Cool
No problem, glad to be of help. [img]graemlins/beers.gif[/img]
