electric fan - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 13th, 01, 03:06 PM Thread Starter
Is an electric fan better than the fan blade at the end of my pully.Does the electric have more cfms than stock driven blades.Thanks for the help.
snake is offline
post #2 of 3 (permalink) Old Mar 13th, 01, 08:31 PM
Dale
All I can say,the fan is only as good as the motor that turns it.I dont know the horsepower of an electric fan motor,but it's a lot less than the one driving my clutch fan.My clutch fan shuts off when it's not needed.I've never felt a electric fan blow my hair around like a engine driven fan.(yeah,like I have hair!)
68 z28 ,68 rs 327 ,73 454 vette, 2 goofy kids
dale68z is offline
post #3 of 3 (permalink) Old Mar 14th, 01, 10:03 AM
Ray
Are you having cooling problems now? If not why bother?
An engine driven fan flows many more cfm's at speed than the electric, but it may not at idle, which is when you really need it.
The best engine driven setup for the street is a clutch fan that engages based on temp and rpm WITH A SHROUD. The shroud is very important unless the fan is very close to the radiator.
Electrics can work well if done right. Most new cars use no engine fan. Or you can use an electric as an extra fan when needed.
If you do go electric then check out SPAL fans, they are some of the best. Also heard good things about 16" Black Magic fan. Lincoln Mark VIII's used a very good 2 speed fan that I've heard works very well.
Ray
68 SS Convertible
Corvette(77) Yellow
383 DFI Fuel Injection
on MiniRamII intake,
Trick Flow heads
700R4, 3.31 12bolt Posi
Guildstrand Mod
AGR 12:1 power steering
[This message has been edited by 68SSConvt (edited 03-14-2001).]
68SSConvt is offline
