69 gas gauge - Team Camaro Tech
post #1 of 5 (permalink) Old May 3rd, 04, 08:11 AM Thread Starter
I have a 69 camaro SS. I have not put a full tank of gas through it as yet. The gas gauge seems to go down fast and I ran out of gas at about 1/8 full. I put in 6 gallons which brought the gauge up to the right side of full , in other words way past full (needle at 3'clock). I did not fill it because I may have to drop the tank. Would this be a faulty gauge or a grounding problem? Any insite would be appreciated.
Tieg is offline
post #2 of 5 (permalink) Old May 3rd, 04, 08:57 AM
Tony
Check 2 things, The grounding at the sending unit and also the grounding of the instument cluster.
Tony:
67 RS Clone, 388 SBC/Keisler TKO 600/12 bolt, 3.90 gear w/posi and a 250 shot of N2O for fun. See my progress at: password is camaro
idoxlr8 is offline
post #3 of 5 (permalink) Old May 3rd, 04, 09:47 AM Thread Starter
Does the instrument cluster have an actual ground strap/wire or just grounded through the dash?
Tieg is offline
post #4 of 5 (permalink) Old May 3rd, 04, 10:16 AM
Zach
this might help you out [img]graemlins/thumbsup.gif[/img]
fuel gauge/sender troubleshooting
69nj350 is offline
post #5 of 5 (permalink) Old May 5th, 04, 01:16 PM Thread Starter
Thanks for the input guys. It was a faulty ground at the back. I used the notes to check the sender etc. Will file them away for future use. Case closed!
Tieg is offline
