'69 Headlamp Switch Knob - Team Camaro Tech
post #1 of 4 (permalink) Old Jun 12th, 00, 07:23 AM Thread Starter
My '69 has a headlamp switch in need of replacement (jiggle the knob to get the dash lamps to illuminate). Can anyone advise me how the knob/handle is removed from the switch so I can remove the switch from under the dash?
Any hints would be appreciated.
glenn396 is offline
post #2 of 4 (permalink) Old Jun 12th, 00, 08:06 AM
DjD
DjD's Avatar
There is a button on the back of the switch thea you must push. At the same time pull on the switch knob. You may have to rotate it before (like dimming the dash lights) it will line up and pull out... Be sure to disconnect your batt before you begin.
That will let you get to the nut that holds the rest of the switch in place...
...Dennis
Topless'69
[email protected]
[This message has been edited by DjD (edited 06-12-2000).]
DjD is offline
post #3 of 4 (permalink) Old Jun 12th, 00, 08:33 AM Thread Starter
Thumbs up
Dennis - Thanks for the speedy reply!!! I'll try it tonight and let you'all know.
Glenn
glenn396 is offline
post #4 of 4 (permalink) Old Jun 12th, 00, 05:29 PM
David Pozzi
davidpozzi's Avatar
glenn396,
Take a look at the front of the switch when you get it off. Usually there is slight corrosion or dirt on the coil spring resistor, or the finger that goes against it. Clean it up and it should work.
The older I get, the faster I was!
davidpozzi is offline
