1969 RS headlights - Team Camaro Tech
post #1 of 8 (permalink) Old Jul 11th, 01, 11:49 AM Thread Starter
Does anyone know if there is an aftermarket, electric, motor kit for 1969 RS headlights?
Thanks, Ryan
Ryan Whittaker is offline
post #2 of 8 (permalink) Old Jul 12th, 01, 02:45 PM
Jeff
Havnet heard of any aftermarket electric kits for the headlights, but i remeber in one post that someone adapted some RX-7 electric motors to work
HawaiianCamaro is offline
post #3 of 8 (permalink) Old Jul 12th, 01, 07:29 PM
mccorry's Avatar
Hi Ryan...
I don't know of any commercial kits, but I do know a guy from the north side of Columbus who adapted power antenna motors to work the hide-aways.
It actually works pretty good....
Steve McCorry - Central Ohio Camaro Club
'69 Camaro RS/SS-350 - Daytona Yellow
'95 Camaro Z-28 - Sebring Silver
click here to see my webpage ---> www.mindspring.com/~mccorry (updated 5/18/01)
[This message has been edited by mccorry (edited 07-13-2001).]
mccorry is offline
post #4 of 8 (permalink) Old Jul 13th, 01, 03:49 AM Thread Starter
Thanks guys for the info. I had heard that 67 or 68 RS's came with electric motors. Do you happen to know if that is true?
Ryan
post #5 of 8 (permalink) Old Jul 13th, 01, 06:36 AM
67's came with electric motors, 68 and 69s came with vacuum operated doors.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #6 of 8 (permalink) Old Jul 13th, 01, 10:19 AM Thread Starter
Mark, do you know if they sell replacement kits for the 67? If so, who sells them? And do you think it could be applied on a 69?
Ryan
post #7 of 8 (permalink) Old Jul 13th, 01, 11:34 AM
Whats the matter with using the original vacuum operated system? It will certainly be cheaper than trying to modify a 67 system or building you own.
Yes, you can get the 67 parts. Don't know of a kit that would include everything but you can buy the motors, limit switches, relays etc. Theres no bargain basement stuff there though. I think the motors alone are somewhere around $200 a piece. You can't use the headlight buckets and brackets from a 67 in a 69, so you would have to figure out a way to graft the bottom end (by the motor) of the 67 setup onto the 69 upper end of the pivot shaft.
The 67 system is probably even more unreliable than the 68/69 system, as it is real easy to burn up your motors if the limit switches aren't setup properly. Personally I'd stock with the stock setup from a 68/69.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #8 of 8 (permalink) Old Jul 14th, 01, 11:30 AM Thread Starter
Mark - I am simply considering all my options. My car is not a true RS. It has an RS front end on it however is missing all of the components for the headlight covers to be functional. I bought the car back in 1987 and just last year decided to tare it apart and make a nice ride out of it. I've found it's a very slow process. The body is currently at the body shop. I tryin to plan ahead for some of the delimas I had before. Thanks for the input.
Ryan
