a little yellow wire? - Team Camaro Tech
post #1 of 7 (permalink) Old Dec 26th, 00, 04:25 PM Thread Starter
Angry
i have a '89 Camaro R/S, and a thin yellow ignition wire fell down from under the dash. it has 1 light blue end and 1 darker blue end. the light blue wire goes up past the stering column and plugs-in near @ the firewall.. it's not an alarm wire, because the car won't start unless it's pushed.. PLEASE HELP!!!
Jnco is offline
post #2 of 7 (permalink) Old Dec 29th, 00, 08:15 AM
If its an auto-trans w/gearshift on the column, it sounds like it came off the neutral safety switch. This wire runs from there to the starter. Hope that helps.
Camaro350
camaro350 is offline
post #3 of 7 (permalink) Old Dec 29th, 00, 01:57 PM Thread Starter
Exclamation
sorry camaro350, but the safty switch already has the wires in. we were looking through the book, and we thought that too. the camaro's a 5 speed manual on the center column. HAVE ANY IDEAS? thanks though camaro350.
Jnco is offline
post #4 of 7 (permalink) Old Dec 29th, 00, 04:55 PM
Could you please clarify "Push it in"? Does the car crank when the key is turned? What do you do to this wire to get the engine to crank and start? It's possible it came from the back of the ignition switch itself. Let me know, it's got me wondering now too what it's off of. Is it possible something was changed/modified and this wire is not even needed?
Camaro350
post #5 of 7 (permalink) Old Jan 2nd, 01, 07:31 AM
the "yellow" wire could be the IDKEY chip identifier wire that goes to the key code reader in the steering column, I just replaced my lock assy on the 91 Fbird because of this , but I dont recall the wire coming from the dash, it came from the top of the column behind the tilt mechanism. I believe the 89 has the identakey mechanism too,
Chris's 67 RS can be seen at http://www.67rs.com
JOIN THE CAMARO NET WEBRING!
Chris Edwards is offline
post #6 of 7 (permalink) Old Jan 2nd, 01, 04:57 PM
safty switch wire on clutch pedal. clutch pushed in to crank maybe
toolbox is offline
post #7 of 7 (permalink) Old Jan 21st, 01, 06:10 PM
Lightbulb
on the '89 camaro's there is a yellow wire that goes to the car security pass key module. it comes off the ignition switch an runs to the ecm. on my '89 iroc, the original owner replaced the ignition switch and bypassed the pass key module and left the wire hanging since it wasn't needed.
trickster is offline
