orange wire? - Team Camaro Tech
post #1 of 13 (permalink) Old Jan 16th, 03, 01:37 PM Thread Starter
Nick
Hello Guys! I got a 67 RS/SS350 with air and I'm redoing the engine harness.I got the old harness out from the fire wall plug and I'm replacing one wire at the time.There are three plugs for the wipers:a plug for the oil/p/s one for the temp, a purple #10 wire for the solonoid, and a yelow from the solonoid to the coil, and the resistor wire for the coil.There is also a orange wire going towards the starter motor but stops short about 16"from it.Can somone tell me where this orange wire goes? Thanks. Mr
MRCOOL_RSSS350 is offline
post #2 of 13 (permalink) Old Jan 16th, 03, 02:20 PM
The blower motor for the heater maybe.
jamie
our cars
"Have you ever notice anybody slower than you is an idiot, and anyone going faster than you is a maniac?
69lemans is offline
post #3 of 13 (permalink) Old Jan 16th, 03, 04:31 PM Thread Starter
Nick
No the htr motor and air/cond, harness comes out on the right side of the car.Before I took the harness apart the orange wire wasn't even sticking out of the harness.It looked like it was burn at the end of the wire,and the ele,tape wasn't broken.There is another wire coming from the horn relay a #10blk wire that goes in to a inline fuse and then to the relay of the htr motor. Mr
post #4 of 13 (permalink) Old Jan 16th, 03, 04:38 PM
Kevin
KevinW's Avatar
On 69s (maybe 67s are the same), the orange wire for the heater was part of the engine harness and could not be removed. If you ordered A/C, the new fan (orange) wire was part of the A/C harness. So the factory just bundled the regular fan wire up with tape on part of the A/C harness. There is a clear pic of the procedure in the 69 C60 section of the Assembly man.
Kevin
KevinW is offline
post #5 of 13 (permalink) Old Jan 16th, 03, 05:25 PM Thread Starter
Nick
Hi Kevin! maybe the 69s are the same as the 67s. my assembly man. for the 67 is not showing the wire.The wire is not bundled up. It's burnt at the end and to short to go anywere.It ends at the top tranny bolt where there is a bracket holding the harness going to the starter mtr.The #10blk wire changes to orange after the inline fuse so maybe that's where the other orange wire went if the car didn't have the a/c. Mr
post #6 of 13 (permalink) Old Jan 17th, 03, 02:56 AM
AAW
Kevin is correct, all (never say all!) 67-68 Camaros had the orange heater blower wire. On an A/C car, the wire was either taped back, or cut off at the edge of the harness. If you have an untouched original harness, you will notice this. (also note, an original harness does not use sticky vinyl tape). The other end of this orange wire, at the firewall bulkhead, will lay dead since there is not a mating wire on the dash side on an original A/C car.
Hope this info helps!
Factory-Fit wiring
AAW is offline
post #7 of 13 (permalink) Old Jan 17th, 03, 05:01 AM
Kevin
KevinW's Avatar
MRCOOL_RSSS350, glad to help, I love mysterys.
Camarocopo, Factory-Fit tech huh? Are you down near Cherry Hill NJ? That's about an hour from me. Do you guys have counter service? I need some 69 power windows harnesses. I always thought that if any layoffs hit me, I would find a local company (like yours) that did Automotive work ( especially for 69 Camaros )
Kevin
KevinW is offline
post #8 of 13 (permalink) Old Jan 17th, 03, 01:16 PM Thread Starter
Nick
Camarocopo and Kevinw tnx for the info,I got my harness all together now.The orange wire is there but not showing!I have another problem with my limit swiches at the rad suport and H/L brackets.I took the car apart in Nov,and didn't make any notes thinking the car will be back from the body shop in a week or two HA!!got the car back last week, thats ok because the car looks great!anyway I forgot which wire goes where? any help on that will be great.Tnx in advance. Mr
post #9 of 13 (permalink) Old Jan 18th, 03, 09:48 PM
on 69's there are two oreang wire that come out of the heater one for the controll and the other from the blower
musclemasterflex is offline
post #10 of 13 (permalink) Old Jan 14th, 06, 07:40 AM
john
Re: orange wire?
does anyone know how rare or the production of a 67 rs/ss 4
speed? this car is for sale but i have no idea what i have!
Welcome! You have entered
john fernandes is offline
post #11 of 13 (permalink) Old Jan 14th, 06, 09:22 AM
click's Avatar
Re: orange wire?
John, Welcome to Team Camaro, you should start a new thread of your own for a question that is not related to the current thread.
Your question is best asked in the Bench section. It will just get lost here in someone elses thread.
click is offline
post #12 of 13 (permalink) Old Jan 17th, 06, 11:21 AM
foreverlookin's Avatar
Re: orange wire?
Hey Nick did you buy a Mustang wiring manual by mistake? Maybe thats your problem!
Call me sometime!
foreverlookin is offline
post #13 of 13 (permalink) Old Jan 17th, 06, 11:45 AM
jerry
Re: orange wire?
For your limit switch wiring and trouble shooting look here
http://www.retro-electro.net/FAQ.html
jerry67 is offline
