High Beam Indicator - Team Camaro Tech
post #1 of 4 (permalink) Old Jan 9th, 01, 02:48 PM Thread Starter
I removed my in-dash guage pod and found that the high-beam indicator light socket is missing. I cant find the wire to repair it. Can anyone tell me where this wire comes from and what color it would be?
http://geocities.com/mike67rs/1.html
Mike67RS is offline
post #2 of 4 (permalink) Old Jan 11th, 01, 01:59 PM
Bruno
Thumbs up
Don't know if your 67 have the same color as 68's but mine is light green and comes out of a wiring harness that travels from the ignition switch area to the lights and wipers.My car is a 68 coupe.
ORENCH is offline
post #3 of 4 (permalink) Old Jan 12th, 01, 08:45 AM
Thumbs up
Mike,
Also don't forget the "coat hanger" ground wire that GM used for the high beam light.
Since the dash pod is plastic, you need to fashion some type of ground "Strap" to the light socket, if you also don't have the wire, which attached to one of the gauge mounting screws.
67LT1 is offline
post #4 of 4 (permalink) Old Jan 12th, 01, 11:40 AM Thread Starter
Thanks. Luckily, I still have the socket carrier and the wire attached. What is missing is the bulb socket and wire. I was able to find a 5/8" universal bulb socket at Auto Zone that fits The carrier perfectly. I'm gonna go look for the wire now. I believe it comes off of the high-beam switch.
Mike67RS is offline
