69 RS headlight vacuum switch diagram - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 4th, 03, 06:29 PM Thread Starter
Which color striped hose goes where on this headlight switch? Does anyone have a diagram to e-mail to me?
'69 RS/SS X-22 M21 Lemans Blue #'s matching. '99 HD Night Train
Big Sky 68Z28 is offline
post #2 of 4 (permalink) Old Sep 5th, 03, 04:24 AM
click's Avatar
orange stripe goes closest to the engine and solid black goes closest to the driver. There is a good layout in the 69 Factory assembly manual. If you dont have it, I suggest you get it for all the other things you will run into.
Its a bear to work under there so I suggest you glue the ends onto the switch, maybe even mini hose clamps too, with about 6" of hose, then use a union to reconnect to the hoses as they exit the dash area. If you ever need to work on that switch it will be easier to disconnect the unions and not worry about reaching under there to re-attach them to the switch in that tight corner. Just my 2cents arent the RS's fun to play with?
good luck [img]graemlins/thumbsup.gif[/img]
click is offline
post #3 of 4 (permalink) Old Sep 5th, 03, 09:30 AM Thread Starter
Jim, They sure are! Never been around a RS before. To make things more difficult, the car came to me in pieces. If I'd been able to disassemble it first it would have been easier going together. I just put the repro dash pad in and it's a good 3/4 inch short. How am I going to fill that? I need to find a oem dash pad. Most repro stuff isn't worth the powder to blow it to ....! Thanks for the help. How was the run in Seattle area?
post #4 of 4 (permalink) Old Sep 5th, 03, 10:55 AM
click's Avatar
seattle was great but the run thru your state was horrible hot, 104 at miles city going both ways, yuck, cool it down there man.
click is offline
