67 RS headlight switch question - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 23rd, 03, 02:31 PM Thread Starter
Rob
Does anyone know if the 67 RS headlight switch is different then the rest?Is it a special application to the hideaway headlights only.What differences if any should I look for.Anyone ever looked into this. Thanks again Rob.
late68 is offline
post #2 of 5 (permalink) Old Jul 23rd, 03, 06:12 PM
I don't know about 67's vs other years, but the R/S switch has a vacuum switch built into it to operate the doors.
-dnult
dnult is offline
post #3 of 5 (permalink) Old Jul 23rd, 03, 06:58 PM
I beleive the 67 is different than that for the 68 because the 67 has electric RS motors not vacuum activated motors [img]graemlins/beers.gif[/img]
67RS RAG is offline
post #4 of 5 (permalink) Old Jul 24th, 03, 01:40 AM
http://www.rickscamaros.com/cgi-loca...133+1072686643
Go to Camaro switches.
Looks to me like you can use the 67 switch on either a standard or an RS.
Randy
67RSM3 is offline
post #5 of 5 (permalink) Old Jul 24th, 03, 04:35 AM
click's Avatar
67's have elec switch contacts for operating the headlight doors, the 68 and 69 have the vacuum connections built into the switch behind the dash, a real bi**h to get at too.
The 67 standard and RS camaro used the same switch, on the RS an extra set of wires utilize extra tabs on the connector, otherwise, same unit.
click is offline
