stumped on bracketry - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 19th, 04, 09:55 PM Thread Starter
I have a 68 engine going in a 69. It has no accessory holes in the heads. Electric water pump. Power steering situated low on driver's side. Headers. I have heard that the belt driven accessories should be on opposite sides to avoid crank loading. With the lower block bolt holes spoken for by the pwr. steering pump, and only the 4 water pump mounting bolts in the neighborhood, I'm not quite sure what I should be figuring off of. I could use some advice on this one. Also any leads on distributors of appropriate brakets. Thanks. Bruce
69hugger is offline
post #2 of 4 (permalink) Old Mar 20th, 04, 04:24 AM
Check out Alan Grove Components. http://www.alangrovecomponents.com
dnult is offline
post #3 of 4 (permalink) Old Mar 20th, 04, 10:33 AM Thread Starter
Nice stuff on their site. But all of the brackets that I saw seem to rely on the accessory holes in the head, or else take the space that the power steering pump will be in. Still scratching my head. Thanks for the lead.
69hugger is offline
post #4 of 4 (permalink) Old Mar 21st, 04, 09:39 AM
i don't think i'd worry too much about crank loading- if it was a problem, my 94 Caprice wouldn't have all the accessories (AC, alt, ps pump, and tensioner) on the passenger side driven by one belt.
you don't plan sincerity.
novaderrik is offline
