Back-up light switch? - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 21st, 01, 06:06 PM Thread Starter
I recently purchased a '69 RS 350 and am working on learning as much as I can about 1st Gen.s. My question: where is the sending unit/switch located on a '69 Camaro with a Muncie M-21 4-speed? (As for now, the lights are there without knowing where the/any wiring goes!)
Thanks for your help!
Chet69RS is offline
post #2 of 6 (permalink) Old Jan 22nd, 01, 12:48 AM
Bruno
In my 68 Camaro 4 speeds, the switch is located in the transmission and is actuated by the shift levers. Is externally mounted with a metal support.
ORENCH is offline
post #3 of 6 (permalink) Old Jan 22nd, 01, 11:49 AM
Great question. I have a '67 with a Borg Warner T-10D (improper). I can't find anything on it either. Is it supposed to have an external switch as well? I can't even find any wiring for it anywhere in the transmission tunnel.
67 RS Convertible, 327/210hp
Granada Gold, deluxe interior (black), 4spd. all stock
67Gold is offline
post #4 of 6 (permalink) Old Jan 22nd, 01, 12:05 PM
Z28 Mark's Avatar
I just had to rig one up. The trany (4-speed Muncie) had a TCI (timing control thing) and I thought it was the back up switch but only had 1 terminal on the switch. I ended up making an L bracket and putting a switch on it and wired it into the circuit. Had to do it this way, I needed to pass a vehicle inspection for a salvaged title.
Z28 Mark is offline
post #5 of 6 (permalink) Old Jan 22nd, 01, 03:14 PM
AJ
'69's had an "interlock" from the steering column to the trans so when the key was removed and the trans in rev, the column was locked and the trans was as well. Soooo the switch is at the bottom of the steering column with 3 (Ithink) wires to it.
Also think that Hurst has a small switch that will mount on the trans that's activated by the reverse rods.
I removed the "interlock" rods so now have no backup lights. Considering the Hurst switch at trans. Any other ideas?
AJ is offline
post #6 of 6 (permalink) Old Jan 23rd, 01, 01:47 AM
Johnny
I used the Hurst switch on my 67 works just fine, was easy to install.
Johnny 1967 RS/SS 396 Camaro
johnnyr is offline
