instrumet cluster not illuminating - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 15th, 03, 07:26 AM Thread Starter
I'm trying to find out what's going on with my lights inside by instrument cluster.
I have a 1994 Camaro Z28. One night the illumination in the instrument cluster went out along with the illumination where the temperature control panel is also. I checked fuses and don't see anything wrong. Instruments work fine, seat belt light works, along with everything else, but no background light. I can't see anything at night. What could be the problem? Thanks in advance,
Wiz
Zenwar is offline
post #2 of 3 (permalink) Old Jan 18th, 03, 02:37 PM
Check a parts store for a bulb. If there is only one then I'd say the lighting is done by one bulb that transmits light thru clear plastic. I'm sure you have already wondered if a christmas tree light company made the system. Better yet check the books for light bulbs at a store like walmart if there's no parts stores or see what's for sale online.
Snatchin'gears is offline
post #3 of 3 (permalink) Old Jan 18th, 03, 03:44 PM Thread Starter
figured it out evenutally, it was the fuse marked IP Dimmer inside fuse box. suppose to be 5 amps but keeps burning out, some electrical overload somewhat, i just upped the fuse to a 20. seems to be okay now.
Zenwar is offline
