help, uhhhhh - Team Camaro Tech
post #1 of 5 (permalink) Old Jan 25th, 03, 07:52 AM Thread Starter
i know it isnt a camaro,but my 84 cutlass with 400 chevy acted up again. i made this post in engine and drivetrain on accident, s didnt get any replies. its a long one. Here it goes, strted fine yesterday morning, my power steering belt was squeling so, i shut it off to adjust it. Wen to start it again, and i was greeted to smoke coming off wires to starter. My solenoid wire is fine. I suspected it was a burntwire from hitting exhaust manifold so i cut out a part that looked bad, wires were showing from below fusible link, and wires got real soft. still smoking, so got a different starter and placed it on air cleaner, hooked up everything, smoke, it only smokes on the wire that goes from big positive post of starter to fusebox. Then i cut out teh fusible link and wired to starter, evrything works fine until key is on ignition, then it smokes, and i lose all power, headlights still work though. do you think the wire burned, then fried fusble link, now without fusible link, it just smokes my wire? thansk this sucks, i need to fix it bymonday, it is a 16 guage fusble link.
mylittle307 is offline
post #2 of 5 (permalink) Old Jan 25th, 03, 12:44 PM
If it only smokes with the key on then you have a dead short to ground somewhere past the ignition switch. Check under the dash for discolored wires. Also check the wire that goes to the distributor. I'm assuming it has an HEI. When you find the short and repair it put a new fusible link on the starter wire. It's there for a reason.
'69 RS Camaro
355 5-speed 4.11
1 2RUN is offline
post #3 of 5 (permalink) Old Jan 28th, 03, 10:08 AM Thread Starter
yep, you were right, im dumb, i took off my valve cover that day to check the rockerarms, and somehow maaged to get the coil wire under the valv cover and tightened it down like that, i fixed it and works good now, uhh, im dumb
post #4 of 5 (permalink) Old Jan 28th, 03, 10:33 AM
Experience is something you don't get until just after you need it.
'69 RS Camaro
355 5-speed 4.11
1 2RUN is offline
post #5 of 5 (permalink) Old Jan 28th, 03, 10:38 AM
That's quite profound, 1 2run.
Everett "OBJECTS IN THE MIRROR APPEAR QUICKLY UPON RAPID DECELERATION"
