Wiper motor issues - Team Camaro Tech
post #1 of 13 (permalink) Old Feb 14th, 05, 11:59 PM Thread Starter
Ken
I'm having the strangest issued with my wiper motor. I just installed a painless wiring kit. My washer motoer grinds and sparks when I turn it on. I made the mistake if touching it and got shocked. Do I have a wiring problem or is the motor shot? I still have the 3 rubber grommets on it.
Ken
CamFrk68 is offline
post #2 of 13 (permalink) Old Feb 15th, 05, 01:44 AM
If I remember, there should be a grounding strap from the wiper case to ground. The rubber bushings are to isolate vibrations. A strap is needed to ground the case to ground.
Others here should correct me if I'm wrong.
post #3 of 13 (permalink) Old Feb 15th, 05, 02:40 AM
Guess
HwyStarJoe's Avatar
I think it's the upper left grommet that is the brass strap that grounds it to the firewall.
But you shouldn't get shocked if it's not there!
You can take it apart very easily and see what's wrong. Sounds like a wire or wires became bare and are touching the case.
HwyStarJoe is offline
post #4 of 13 (permalink) Old Feb 15th, 05, 03:54 AM
While I don't yet have any insight on this particular problem, more details would be nice, what do the wiper themselves do and such... but...
When you troubleshoot this, remember the wipers on our cars are wired a little weird. 12 volts is supplied when ever the key is out of the "OFF" position, and the high / low / wash functions are triggered by the switch gounding one of the other wires.
I'd for sure look at / actually check that ground. It's where Joe said, and is a small brass strap that is riveted to the motor baseplate and extends over the grommet, under the screw. My replacment came in with that area painted, and wouldn't work right untill I scraped the paint off. If the firewall has a lot of paint on it under that screw/grommet, that can cause trouble too.
post #5 of 13 (permalink) Old Feb 15th, 05, 08:45 AM Thread Starter
Ken
There does not appear to be a ground strap on my wiper motor or grommets. That may be my problem. when I turn my wipers on it sounds like gears grinding and there is sparking coming from the side of the wiper motor facing the fire wall. At first I thought the sparking was from gears grinding until i got shocked.
Ken
CamFrk68 is offline
post #6 of 13 (permalink) Old Feb 15th, 05, 09:13 AM
Guess
HwyStarJoe's Avatar
Sounds like a bad motor or wires internally.
Here's a few shots of the motor with cover removed:
Internal wiring:
Again:
You can see that there are three wires (black, white, red) coming from the base plate, through to the electrical motor itself. One or more of them could be frayed and touching a part of the case inside. You can see the motor winding (stator?) removed from the case, and if you look close, you can see the two hard brushes that contact its shaft when it's inserted into the case. There are a series of wires connecting all of this together.
Take the cover off carefully (it won't release from the base because of the three wires) by removing the two 5" long screws holding it on. The flat cover on the end of the case will come right off. Be careful of shims. Then the motor winding section will lift out. Again, watch for small shims.... there's a couple on both ends of the shaft. Take a close look at everything. You might be able to repair it. I know the junkyards are full of suitable replacements. People don't think to take this kind of thing out of Novas, Omegas, etc. They all use the same wiper motor, as do a bunch of other makes\models.
post #7 of 13 (permalink) Old Feb 15th, 05, 09:21 AM
Hello
hmm something sounds definitely not quite right especially if your getting a shock off the motor, as people have said before take it apart and check it out!
my question is regarding the wiper motor etc is cant get my washer jets on this to squirt!
the wipers work but i get no water when i push the wiper switch in any ideas?
Is the pushing in of the wiper switch the way to turn the jets on etc?
Cheers
Andy
Andrzejb is offline
post #8 of 13 (permalink) Old Feb 15th, 05, 10:15 AM
BINGO!!! The light goes on. The missing ground is the problem.
The spraks you see are the current seeking ground THRU THE LINKAGE!
post #9 of 13 (permalink) Old Feb 15th, 05, 04:52 PM
I have a similar problem with my wiper motor. Everytime I tried to hook up the linkage to the motor it arced like crazy, I put a voltmeter on the motor and every metal part on it had 12v, but the motor worked like it was supposed to until I tried to hook up the linkage then it arced. I went and bought a new wiper motor and installed it. Now it won't stop blowing fuses. The only thing I can think of was the motor was not grounding because the grounding strap and firewall had paint on them. Now that it is making a good ground it is shorting out. Now I see why the guy that owned the car before me left the wipers disconnected.
Could all this be just that we have our wires mixed up?
CamFrk68 if you figure anything out let me know.
Dino
CanCamaro is offline
post #10 of 13 (permalink) Old Feb 15th, 05, 04:58 PM
Just a quick note, I didn't see my grounding strap on my old wiper motor either until I was removing the rubber mounting gromlets. Maybe it's just painted black like mine was.
Dino
67 camaro 462 BB 9.6 CR Compcams 314HR 252 @ 50 612 lift, Port+Polish Oval port 2.19 1.88, Edelbrock RPM intake, 850 Holley DP, 3" exhaust, turbo 400 TCI 4000 stall, Dana 60 4.10 posi, 315/60/15 BFG M/T drag Radials, 3650lbs. w/driver. [email protected]
post #11 of 13 (permalink) Old Feb 20th, 05, 05:33 PM
Paul
Hi Everyone,
I had the same problem less than a year ago.It turned out that the grinding was due to sand from previous sand blasting had entered the housing and was grinding everything up inside when the motor was powered up. It also caused my motor to short out and ground against the firewall. Sparks, burnt fuses, shocks and a motor that wouldn't stop when the switch was turned off were the end results until I went out and bought a rebuilt unit. Everything's back to normal. Goood Luck , Paul
paul1969 is offline
post #12 of 13 (permalink) Old Feb 20th, 05, 05:43 PM
Paul
Here's a link to a previous post by KevinW. If you decide to test the wiper motor itself, you'll find this extremely helpful. I too thought it was my wiring, but was wrong. Thank you again KevinW!!
https://www.camaros.net/cgi-bin/forum...0.html?#000000
paul1969 is offline
post #13 of 13 (permalink) Old Feb 21st, 05, 06:45 PM
... [/QB]
Inductive loads like Motors can do strange things. A motor winding can generate flyback voltage spikes in excees of 100 volts if a resistance is in the circuit (like a bad ground). 12 volts is enough to feel if a sensative part of your body completes the circuits. I've felt a twinge on the bottom of my fore-arms a few times. If you're wet, I'm sure you would feel it more.
dnult is offline
